Quattro 20 Posted November 4 Share Posted November 4 My 45yo boat has a switch bank with all the usual stuff. The bilge switch is the older, two-way, on-off type. I've upgraded the bilge pump, with auto float switch, but now realise i need to update the switch. I don't want to cut holes for a new switch, so my question is: can I upgrade the 2way switch to a three way to suit the automatic function? I note that the 3 way switch, which fits the panel, is 'off-on-off' so wonder if wiring it differently would make it off-on-automatic? Appreciate any advice or ideas on this. Quote Link to post Share on other sites
aardvarkash10 1,187 Posted November 4 Share Posted November 4 Typical 3 way switches are centre-off, not centre-on. Is it a toggle style switch or one of those horrid BEP flat rocker switch? Quote Link to post Share on other sites
aardvarkash10 1,187 Posted November 4 Share Posted November 4 Typical 3 way switches are centre-off, not centre-on. Is it a toggle style switch or one of those horrid BEP flat rocker switch? In any case, you could leave the original switch in place to operate the pump manually and run a separate FUSED live supply to the auto switch. https://www.twoboat.com/guides/how-to-connect-a-bilge-pump Quote Link to post Share on other sites
Quattro 20 Posted November 4 Author Share Posted November 4 Hi Ash, you're talking about foreign language to me. I haven't bought a new switch as yet, wanting to know my options. Yes, centre off, but can I assign one side to automatic? But doing something artful with the wiring? Like your second point. Any diagram that you can share? Quote Link to post Share on other sites
Quattro 20 Posted November 4 Author Share Posted November 4 I'm on the gard at Grangers Point prepping for coppercoat soon. Quote Link to post Share on other sites
Quattro 20 Posted November 4 Author Share Posted November 4 Otherwise looking at a rocker type 3 way switch, to locate somewhere. c498d31f-7cbc-4a52-86d7-99be5229cedd (1).pdf Quote Link to post Share on other sites
aardvarkash10 1,187 Posted November 4 Share Posted November 4 Diagram for the "use your old switch" option is now in my previous post. With a centre off switch, yes. One side is auto, centre is no power to the pump at all, other side is manual. https://manuals.plus/seaflo/sfbp1-g600-11-automatic-bilge-pump-manual The switch itself should have three pins (possibly 4 if it's illuminated). One pin is your live supply, one goes to the float switch on the pump, the other directly to the pump. If it has a 4th terminal it is probably an earth for the illumination. Quote Link to post Share on other sites
Black Panther 1,849 Posted November 5 Share Posted November 5 I had a similar issue with a new masthead light. Ended up using 2 switches Quote Link to post Share on other sites
bazzathemammoth 38 Posted yesterday at 08:03 PM Share Posted yesterday at 08:03 PM Do you need something like this? https://www.supercheapauto.co.nz/p/sca-sca-toggle-switch-12-24v-on-off-on-metal/716680.html Quote Link to post Share on other sites
Quattro 20 Posted 22 hours ago Author Share Posted 22 hours ago Yes. Well I was originally going down that line, but I've just bought a 3 way bilge pump switch that should for the trick. Thanks Quote Link to post Share on other sites
