LBD 126 Posted March 4, 2023 Share Posted March 4, 2023 I got me a new boat.... for the price of some paint, hose clamps, some sanitary hose...well she smells like a new boat with the sweet Linseed bouquet and no toilet odors... 2 2 Quote Link to post Share on other sites
aardvarkash10 954 Posted March 5, 2023 Share Posted March 5, 2023 Toilet vent plumbing is on the list for us too. Ok over summer with everything open, but a bit rank when you have to close hatches in rain ... Quote Link to post Share on other sites
LBD 126 Posted March 5, 2023 Share Posted March 5, 2023 19 minutes ago, aardvarkash10 said: Toilet vent plumbing is on the list for us too. Ok over summer with everything open, but a bit rank when you have to close hatches in rain ... Yes, must have a good vent to prevent siphoning... the problem I inherited was the use of non sanitation hose, which for those who who do not know... can let odors through the hose wall. I my case it was extreme, wife made a point of "Fix it or else!"... and I would fully expect any other crew to mutiny. 1 Quote Link to post Share on other sites
LBD 126 Posted March 5, 2023 Share Posted March 5, 2023 This is the stuff I used from Lusty Blundel... not cheap and worth every penny 1 Quote Link to post Share on other sites
Island Time 1,230 Posted March 5, 2023 Share Posted March 5, 2023 all sanitation hose breaks down eventually. use a rag with boiling water on it - rub it on the hose - then smell the rag. if it smells, replace the hose.... 2 Quote Link to post Share on other sites
Psyche 626 Posted March 5, 2023 Share Posted March 5, 2023 On 4/03/2023 at 7:04 PM, Ex Machina said: Cool looking boat …what is it again ? Have a similar looking boat at our club , a Beale 780 Its a Beale 10.something Quote Link to post Share on other sites
Frank 157 Posted March 5, 2023 Share Posted March 5, 2023 Seems like you were down the coal hole for a wee while on that very tidy installation. I started using some of that blue coloured additive when I installed the holding tank on our Carpenter, it seems to stop the horrible smells. I'll fess up and admit I don't know what its environmental credentials are like, just add a capful when flushing a no 2. For my sins I replaced two magnificent but frozen Bronze Sea Cocks with Nylon/glass units and replumbed the cockpit drains on the Hood 38 and the next job was to replace the steering cable, which was fun but at least I know how it works now. Being an old school hull shape the boat is narrow at the stern so both jobs required a fair degree of contortion in the coal hole. 1 Quote Link to post Share on other sites
Black Panther 1,581 Posted March 7, 2023 Share Posted March 7, 2023 Angela is filling out a census form and they want to know if our home is damp. Rude buggers. I told her to write "only below the waterline". 3 Quote Link to post Share on other sites
aardvarkash10 954 Posted March 7, 2023 Share Posted March 7, 2023 I hears a comment on the radio - you must be RNZ listeners... Quote Link to post Share on other sites
Addem 94 Posted March 7, 2023 Share Posted March 7, 2023 On 6/03/2023 at 5:10 AM, Frank said: Seems like you were down the coal hole for a wee while on that very tidy installation. I started using some of that blue coloured additive when I installed the holding tank on our Carpenter, it seems to stop the horrible smells. I'll fess up and admit I don't know what its environmental credentials are like, just add a capful when flushing a no 2. Does anyone have a solution for the stagnant water in the water feed line which reeks to eternity when first flushed after sitting for a week or more? I put the blue stuff(from Rv shop) in the bowl but can't get rid of the seawater in the line (which is quite long in my boat) - this goes off and stinks really bad. Quote Link to post Share on other sites
Island Time 1,230 Posted March 7, 2023 Share Posted March 7, 2023 6 minutes ago, Addem said: Does anyone have a solution for the stagnant water in the water feed line which reeks to eternity when first flushed after sitting for a week or more? I put the blue stuff(from Rv shop) in the bowl but can't get rid of the seawater in the line (which is quite long in my boat) - this goes off and stinks really bad. The only solution is a fresh water toilet, or converting to a waterless toilet (composting). The rotten egg smell is caused by the biological life dying and decomposing in the seawater feed...inlet - before the toilet, so no additives at the toilet can work. Quote Link to post Share on other sites
LBD 126 Posted March 7, 2023 Share Posted March 7, 2023 25 minutes ago, Island Time said: The only solution is a fresh water toilet, or converting to a waterless toilet (composting). The rotten egg smell is caused by the biological life dying and decomposing in the seawater feed...inlet - before the toilet, so no additives at the toilet can work. If it is a problem you really want to solve, then put a tee in the line near the anti syphon valve, with a cap. When leaving the boat and before closing the sea suction to the toilet, remove the cap, purge the line with fresh water then close the sea suction.... I do not do this, but I do purge the toilet with fresh water before closing up for a time Quote Link to post Share on other sites
funlovincriminal 162 Posted March 7, 2023 Share Posted March 7, 2023 When we refitted our 1020 I deleted one of the through hulls where it had a toilet inlet and hand basin waste outlet next to each other. I have a Y just inboard of the sea cock now, below waterline and leading off to WC and Basin. Behaves as normal, but after motoring home from a trip and running a fair amount of Salt water through WC and holding tank I can shut sea cock and fill hand basin with fresh water, with the plug out and toilet flushing it only gets fresh water so no sea life dying in system when boat parked. Seems to work fine. 1 2 Quote Link to post Share on other sites
strath 4 Posted March 8, 2023 Share Posted March 8, 2023 When we get back the the marina we pour at least half a bucket of fresh water, plus a spash of blue stuff, into the toilet boil, pump it out using dry boil action. Dont seem to have any smell troubles. Quote Link to post Share on other sites
Adrianp 119 Posted March 8, 2023 Share Posted March 8, 2023 1 hour ago, funlovincriminal said: When we refitted our 1020 I deleted one of the through hulls where it had a toilet inlet and hand basin waste outlet next to each other. I have a Y just inboard of the sea cock now, below waterline and leading off to WC and Basin. Behaves as normal, but after motoring home from a trip and running a fair amount of Salt water through WC and holding tank I can shut sea cock and fill hand basin with fresh water, with the plug out and toilet flushing it only gets fresh water so no sea life dying in system when boat parked. Seems to work fine. Thats bloody cleaver and I'm going to steal that idea! 1 Quote Link to post Share on other sites
Addem 94 Posted March 8, 2023 Share Posted March 8, 2023 4 hours ago, strath said: When we get back the the marina we pour at least half a bucket of fresh water, plus a spash of blue stuff, into the toilet boil, pump it out using dry boil action. Dont seem to have any smell troubles. While the other two solutions proposed are what I'll probably do, I feel like a complete dummy as i don't know what a dry bowl action is? If you mean the empty bowl switch, I've tried it and the salty organism filled water doesn't purge. Also, for clarity the roten egg stink only happens the first flush when the head is first used. But takes an age for the odour to dissipate. Quote Link to post Share on other sites
Black Panther 1,581 Posted March 8, 2023 Share Posted March 8, 2023 A squirt of dishwashing liquid as you leave the boat and after the first flysh when you return. Problem solved. 1 Quote Link to post Share on other sites
ex Elly 197 Posted March 8, 2023 Share Posted March 8, 2023 6 hours ago, funlovincriminal said: When we refitted our 1020 I deleted one of the through hulls where it had a toilet inlet and hand basin waste outlet next to each other. I have a Y just inboard of the sea cock now, below waterline and leading off to WC and Basin. Mine has a similar arrangement. Can pump fresh water into the toilet by closing the seacock, and running the tap in the basin. Quote Link to post Share on other sites
aardvarkash10 954 Posted March 8, 2023 Share Posted March 8, 2023 Not quite the last weekend, but pretty happy to get a Mariner Stainless Kero stove as a trade for a 6 pack of cider. I spent a hundy on some new bits and it's now running in in the outdoor fireplace at home. It will move to SO once it's proven wrinkle-free. Full gory detail on the restoration can be found here. Quote Link to post Share on other sites
Black Panther 1,581 Posted March 8, 2023 Share Posted March 8, 2023 Lived off that for over 8 years. Good product. Quote Link to post Share on other sites
