Guest Posted July 20, 2013 Share Posted July 20, 2013 nice work, are you stiffening her up for the fiji race next year? Quote Link to post Share on other sites
Guest Posted July 20, 2013 Share Posted July 20, 2013 just out of curiosity, what laminate have you added to the chainplates (what was there originally?) and what will you use to tape the new frame in? Quote Link to post Share on other sites
Changed 10 Posted July 20, 2013 Share Posted July 20, 2013 The laminate consists of 900 grammes of carbon around the hull which joins on the keel floors and layers of double bias to bind it together. The cabin top beam is two layers of e glass unis and then the beam will be formed using 378 gramme carbon uni tape and carbon double bias tape. It will then be foam shaped and finished in boat cloth for painting. This was more about stiffening the boat than replacing the chain plates. The frame that is now an integral part of the chain plate will also stiffen the hull which will allow us to extract more rig tension as well. Quote Link to post Share on other sites
Guest Posted July 21, 2013 Share Posted July 21, 2013 I guess Mr Ross recommended these changes? Quote Link to post Share on other sites
Guest Posted July 22, 2013 Share Posted July 22, 2013 Contemplated whether plying Otto with beers and them allowing him near power tools was really that smart of an idea. Quote Link to post Share on other sites
SloopJohnB 337 Posted July 22, 2013 Share Posted July 22, 2013 You could have saved the cockpit if you opened the hatchway. Quote Link to post Share on other sites
Guest Posted July 22, 2013 Share Posted July 22, 2013 Will it go sailing again or is it a garden ornament now?? Quote Link to post Share on other sites
Guest Posted July 22, 2013 Share Posted July 22, 2013 Time will tell but it's going move either to a pedestal or a harbour by mid January. It's currently sitting in our new kitchen Quote Link to post Share on other sites
BNG 56 Posted July 22, 2013 Share Posted July 22, 2013 Fill it with Jelly and chuck the Missus and one of her friends in. Quote Link to post Share on other sites
Guest Posted July 22, 2013 Share Posted July 22, 2013 oh for a second there i thought you were going to say daug..... Quote Link to post Share on other sites
otto 31 Posted July 22, 2013 Share Posted July 22, 2013 Oy if i didn't get side tracked by a flat sea and a fishing line would have had the transom out as well. oh for a second there i thought you were going to say daug..... oh no i can see the shotgun getting cleaned again Quote Link to post Share on other sites
Kiteroa 8 Posted July 22, 2013 Share Posted July 22, 2013 Wow, and I thought I had some boat building to do! Quote Link to post Share on other sites
Guest Posted July 22, 2013 Share Posted July 22, 2013 It looks worse than it is. Found a few spots that were going to be a worry in a season or 2 so this is good timing. Hard investigation of all that stuff shows it to be related to the last tickle she had so it's contained and easily found. Knot huge stuff just sneaking water and some untreated wood used in spots so the start of some small rot issues, all of which have now been removed. None in structural areas, mostly in the water ingress stopping. All the import parts are good to go..... maybe after we buff out a few blemishes in the cockpit Now where can I get 200lts of jelly?? Quote Link to post Share on other sites
rigger 47 Posted July 23, 2013 Share Posted July 23, 2013 Now where can I get 200lts of jelly?? http://www.stuff.co.nz/oddstuff/3747969 ... ilm-makers Quote Link to post Share on other sites
Guest Posted July 23, 2013 Share Posted July 23, 2013 nearly ready to splash some rum on this puppy Quote Link to post Share on other sites
Kiteroa 8 Posted July 23, 2013 Share Posted July 23, 2013 In other proper Piedy news, I'm almost done with the new cockpit on the Rat. Quote Link to post Share on other sites
Guest Posted July 23, 2013 Share Posted July 23, 2013 In other proper Piedy news, I'm almost done with the new cockpit on the Rat. Quote Link to post Share on other sites
Guest Posted July 27, 2013 Share Posted July 27, 2013 splash tomorrow Quote Link to post Share on other sites
Guest Posted July 27, 2013 Share Posted July 27, 2013 looks a bit like a Piedy. Quote Link to post Share on other sites
otto 31 Posted July 28, 2013 Share Posted July 28, 2013 splash tomorrow Hope there's a bit more water than that or it might go Bump. See Coyote still lurking in the photos Quote Link to post Share on other sites
