too_tall 15 Posted January 23, 2012 Share Posted January 23, 2012 Remember that you need different gauges for different gasses - or at the very least, adapters because they almost all run at different pressures, and you want accurate gauges, so need them to be reading the correct range over a large portion of their scale. Fridge work is not hard, but it does require a methodical approach. Gauges and a vac pump are not overly expensive, but carrying several different types of gas can be!. I have learn't a lot about fridge work fixing chiller units at cowsheds over the years - when it costs about $400 to get someone out between 5pm and 8am, or more in the weekend, I soon figured I needed to learn how to do it myself!. That being said, those are of a different scale to the gear used in boats ( 10Kw plus ) and I am not sure if the smaller gear would be easier or harder to work on. More fiddly no doubt. And smithy, I ALWAYS replace the driers whenever I "open" the system, its well worth it. Liquid does not compress well, and any moisture in the refrigerant gas can cause a magnitude of problems which will not only stop the system working, but will cost a motherload more to fix than a drier. I even installed driers on my house heat pumps. Link to post Share on other sites
smithy09 50 Posted January 23, 2012 Author Share Posted January 23, 2012 Thanks Too Tall. All good stuff and interesting.. Link to post Share on other sites
