Drive Coupling........Any Help appreciated
NZMackem
To the left in the adds column, a company called Transdiesel could be worth an ask. Otherwise any engineering supplier, like Blackwoods, the Engineering supplier down near Orams, Tradezone and so on. It should be a item off the shelf. However, it will need to be bored to suit the shafts and so you may need an engineer to supply and sort for you.
Thanks for the advice, but looks like it might be a little bit harder than that. It has a three hole plate that fits to the gearbox flange.
I have one possibility, but would like to source the actual part.
That would be called a Flange and it will most likely come blank and will need to be drilled. The couplings don't normally come with a motor and chances are the exact same coupling may not be available anymore. Any make of coupling will suit. Just make sure it is the same type of coupling. As in, in most lkely is a captive coupling. It takes the thrust on the shaft.
Thanks for the advice, after an exhaustive search around AKL, Chatfield Marine in Takapuna, are gonna make me one.
Hopefully before the weekend ?????
Reynolds chain used to have "blanks"for these
