Jonquil 545 Posted April 27, 2010 Share Posted April 27, 2010 Can anyone point me in the right direction for putting Sundreamer into survey to carry fare-paying passengers for daysailing? It's always been a long term dream of mine. Link to post Share on other sites
rigger 47 Posted April 27, 2010 Share Posted April 27, 2010 Get in touch with one of the SSM companies, you'll need one anyway and they can set you of on the right track - hopefully have a look at http://www.maritimenz.govt.nz/Commercial/Commercial.asp SSM companies http://www.maritimenz.govt.nz/Commercia ... ompany.asp A Guide http://www.maritimenz.govt.nz/Publicati ... t-2009.pdf These steps summarise the process to get a vessel’s safe ship management certificate. 1.Decide if your vessel is (or will be) used for fishing, passengers, non passengers or a combination of these. 2.Choose your safe ship management company. (see link below) 3.Discuss the scope of your operation with your safe ship management company. 4.Draw up and sign a contract (membership document) with your safe ship management company. 5.Is your vessel yet to be built or an existing vessel? 6.For a new build, get design approval from one of Maritime New Zealand’s approved design companies. (see link below). Build the vessel under supervision of one of Maritime New Zealand’s recognised surveyors. (see link below) 7.For an existing vessel, find out if it has design approval. Where the design has already been approved, get a letter from an approved safe ship management company stating design approval is not required. Otherwise get design approval from one of Maritime New Zealand’s approved design companies. (see link below). Following design approval, present your vessel for initial inspection by one of Maritime New Zealand’s recognised surveyors. (see link below) 8.Your safe ship management company needs to get a MSA number for your vessel 9.You need to get all of the required certificates for your vessel. Register your vessel for national if applicable. 10.Correct all deficiencies and get a fit for purpose document 11.Get approval for your safe ship management manual and maintenance plan. 12.Address all health and safety requirements. 13.Get your three-month exemption certificate. 14.Begin operating commercially. During this time ensure your safe ship management manual is made ship specific 15.Present your vessel for an initial audit well before expiry of your exemption certificate. 16.Attend to any corrective actions arising from the audit within agreed time frames and before your exemption certificate expires. 17.Get your safe ship management certificate. 18.Display your safe ship management certificate on your vessel. Link to post Share on other sites
rigger 47 Posted April 27, 2010 Share Posted April 27, 2010 By the way the entire SSM system is up for change, new rules (part 19 and 44) are under discussion now. Not sure if it would be better to get in under the current system or wait for the new one, either way it costs. Link to post Share on other sites
Jonquil 545 Posted April 28, 2010 Author Share Posted April 28, 2010 Thanks rigger. Any recomendations as to which of the companies listed would be most suitable for a classic yacht? Link to post Share on other sites
rigger 47 Posted April 28, 2010 Share Posted April 28, 2010 Dunsford know a bit about sailing vessels - Talk to Bob Link to post Share on other sites
Guest Posted April 28, 2010 Share Posted April 28, 2010 Unless you love bureaucratic BS then have a handy supply of valium available. There is a large disparity between SSM requirements & YNZ category. Link to post Share on other sites
grant 46 Posted April 28, 2010 Share Posted April 28, 2010 there was a proposal (currently on the shelf) to make yachts available for 'sailing instruction' or similar, the requirements for the vessel were more in line with YNZ and from memory the masters certification was also involved with the YNZ courses. If you're in no rush that may make life easier to see if that is going to happen. Talk to Alistair Thompson at MNZ in Auckland , 093061086 who will be able to give you more 9information and any possible time frame. I think it was an amendment to Part 40 under the heading of Sail training, Alistair will know. Otherwise take a deep breath and set aside plenty of time and buy in a case of whatever calms you down in the evening Link to post Share on other sites
Jonquil 545 Posted April 28, 2010 Author Share Posted April 28, 2010 Thanks guys (pm's received) It's always comforting when multiple people recommend the same person. Link to post Share on other sites
ScottiE 174 Posted April 29, 2010 Share Posted April 29, 2010 Good to hear there's a highly recommended person out there. Can just imagine SD's conversation with a clipboard carrying muppet to this criteria "7.For an existing vessel, find out if it has design approval. Where the design has already been approved, get a letter from an approved safe ship management company stating design approval is not required. Otherwise get design approval from one of Maritime New Zealand’s approved design companies." clipboard carrying muppet (ccm): "Designers name?" SD: "Barker" ccm: "I don't recognise that name - what does he specialise in?" SD: "water colours mostly - some sculpture" Link to post Share on other sites
Guest Posted April 29, 2010 Share Posted April 29, 2010 I see a strong theme in these posts SD, as I mentioned myself. That being 'stock up on calming substances, you will need it'. Having been there done that, there is no way I can disagree. Link to post Share on other sites
Guest Posted May 24, 2010 Share Posted May 24, 2010 Many , many years ago (early eighties) boats of under 8m were exempt (pretty sure) - still the case? Or was I confused - we were doing it for Taupo so maybe it was inshore or something like that. Anybody got any ideas? Link to post Share on other sites
The big T 45 Posted May 25, 2010 Share Posted May 25, 2010 Pretty sure the cut off used to be 6 metres - I remember a paragliding guy that had to cut the bow off his boat to get under the length. Gone by the wayside now - in a previous job I put a 12 ft Fyran into a Safe Ship management programme. Was a first and quite entertaining. Link to post Share on other sites
Guest Posted May 25, 2010 Share Posted May 25, 2010 Cool - thanks for clarifying BT. It was a long long time ago. EE Link to post Share on other sites
Jonquil 545 Posted May 25, 2010 Author Share Posted May 25, 2010 Word so far is that it is doable, main concern being the lack of drawings and specifications. Nothing that time and money can't fix. We will not be changing her look in any way. Link to post Share on other sites
Guest Posted May 25, 2010 Share Posted May 25, 2010 I doubt you'll have much drama there SD. Your fine beast has got a good track record with regards to knot flying to pieces. That will help a lot. Be very interest to see how you go and any traps you find along the way. Link to post Share on other sites
