Bad Kitty 342 Posted May 6, 2012 Share Posted May 6, 2012 Thought I'd put up a few photos of the carbon rudder project for Bad Kitty, won't write much but if you have any questions fire away, starting with stock build, Foam core wrapped in 23 layers of prepreg carbon, Link to post Share on other sites
Bad Kitty 342 Posted May 6, 2012 Author Share Posted May 6, 2012 Then cooking them, The finished blank stock Link to post Share on other sites
Bad Kitty 342 Posted May 6, 2012 Author Share Posted May 6, 2012 Then lay up eglass for bearing surfaces, glue it on so Jamie @ Custom Marine could turn it round & add stainless bearing surfaces. While that's going on pull an existing rudder to copy, Make 2 moulds & make carbon skins, Link to post Share on other sites
Bad Kitty 342 Posted May 6, 2012 Author Share Posted May 6, 2012 Also want to change the cast bronze tillers to something a bit more 21st Century, Link to post Share on other sites
203 0 Posted May 6, 2012 Share Posted May 6, 2012 looking very nice! Good job Link to post Share on other sites
Hurts 6 Posted May 6, 2012 Share Posted May 6, 2012 Very nice - looks like you know what you are doing - what sort of boat is bad kitty? Link to post Share on other sites
Variant 2 Posted May 6, 2012 Share Posted May 6, 2012 What material have you used for the core of the stock? Link to post Share on other sites
Bad Kitty 342 Posted May 6, 2012 Author Share Posted May 6, 2012 Very nice - looks like you know what you are doing - what sort of boat is bad kitty? Cruising Cat, Link to post Share on other sites
Bad Kitty 342 Posted May 6, 2012 Author Share Posted May 6, 2012 What material have you used for the core of the stock? PVC Foam, one of those generic core materials ex SP High Modulus, 80kg I think without checking? Link to post Share on other sites
Bad Kitty 342 Posted May 6, 2012 Author Share Posted May 6, 2012 Very nice - looks like you know what you are doing - what sort of boat is bad kitty? Link to post Share on other sites
Bad Kitty 342 Posted May 6, 2012 Author Share Posted May 6, 2012 Looks like you know what you are doing? Nope, I'm just labour, and pretty unskilled at that, luckily my wife is a lot smarter than me! Link to post Share on other sites
BelowPAR 0 Posted May 6, 2012 Share Posted May 6, 2012 Nice pics thanks! What is the cloth in the very first picture?? Ta Ben Link to post Share on other sites
Bad Kitty 342 Posted May 6, 2012 Author Share Posted May 6, 2012 Nice pics thanks! What is the cloth in the very first picture?? Ta Ben That's the prepreg carbon, or are you asking exactly what carbon it is? I'll check in the freezer & tell you later! Link to post Share on other sites
smithy09 50 Posted May 6, 2012 Share Posted May 6, 2012 Jeeze I gotta get educated in that construction. It looks just way cool and I can think of 100 applications on the Marshall.. Nice job guys! Link to post Share on other sites
BelowPAR 0 Posted May 7, 2012 Share Posted May 7, 2012 Just curious as it looks like uni in the second pic but plain or twill weave in the first. Was wondering if it was a bit gucci? Thatd be cool thanks. Link to post Share on other sites
Bad Kitty 342 Posted May 7, 2012 Author Share Posted May 7, 2012 Just curious as it looks like uni in the second pic but plain or twill weave in the first. Was wondering if it was a bit gucci? Thatd be cool thanks. 200 gram carbon uni, prepreg. It goes on in some highly important order, at 0, 45, 90 degrees or something like that, over & over till you have 23 layers. If you want to get more specific I'll have to check with the Engineer! In the second photo the carbon on the right still has the plastic on the top surface. Link to post Share on other sites
1paulg 22 Posted May 7, 2012 Share Posted May 7, 2012 Looks great ..could do with that on my dagger boards!! (wish list!) Link to post Share on other sites
Bad Kitty 342 Posted May 7, 2012 Author Share Posted May 7, 2012 Carbon tillers, between steering ram & rudder stock. Replacing cast bronze things that weigh about 4kgs each. In carbon 164grams Link to post Share on other sites
Bad Kitty 342 Posted May 7, 2012 Author Share Posted May 7, 2012 And here's the first one almost finished, just a bit of a tidy up, tape the leading edge and done! Old rudders with 50mm 2205 stainless stocks & bronze tillers, blades made of foam & eglass = total weight 28kg each. Carbon stock, blade & tiller = 7.1kg each. Thanks to; Nina, Clever Fox Engineering. Engineering and nearly all of the work. Jamie Logan, Custom Marine. Machining and technical help. Richard Edlin, mould making & boatbuilding. Willy, bugger all labour, cockad a few things up which meant more work for the first 3, did buy the lunches, beer & Mt Gay. Link to post Share on other sites
Guest Posted May 7, 2012 Share Posted May 7, 2012 A great way to make the whole thing look easy! Well done. Link to post Share on other sites
