timberwolf
Rudder Gudgeons.
High density Foam is carboned over.
Bearing is made from Orkot which glues well.
then Carbon Unis over Bearing onto transom.
Very strong, simple and cheap, and Bearings last for ages.
Tim - What's the reason for wrapping the carbon 'under' the bearing in that fashion - are you trying to resist forward thrust or just the bearing 'squashing' the foam in some situations. Does look very sexy though!
A
A
To Stop the Orkot bearing from squashing into the HD foam.
If there is no laminate on the HD, the Unis on the outside of the bearing are in peel if the foam starts to squash.
The laminate spreads the load, and this way the carbon encapsulates the bearing.
Fear not Pedro, I have used this system for a good many years now, the Orkot bearings last ages, and it is extremely reliable.
They look flash Tim. Are they cnc cut?
Yes.
they need to be perfect to fit properly and slide easily in the bearings.
as they are so assymetric it is vital that the windward one is lifted clear of the water.
Last night we got the second ama joined together.
Was a fantastic team effort, thank you very much to all the guys that helped.
All remaining now on ama2 is to Laminate the outside, then fill and fair.
Looking good to make Bay week !
since this drawing was done, we have made the foil angle less aggressive, as we were informed that BMW tried this style and ended up porpoising.
i.e. too much lift and the whole foil comes up out of the water, cavitates, and back down you go, then once it bites again, back up you go etc....
At 15 knots our foil should provide around 350 kg of lift in its current configuration, if that is too much we will just have to pull it up,
With such a big case we still have the opportunity to play around with all the various angles involved.
The pictures show the beam sockets now Carboned in place and the holes at the ends of the sockets filled and carboned over.
There are plinths where the various fittings will go along with those for the Inspection Ports.
There is a Carbon fitting where the Topmast backstays attach along with the Tramp lashing tubes.
Hows progress on the port float?
is it easier to fair the hull before putting the fittings on, (i.e. tramp tracks) then grinding the bog off, secondary bond, then re-fair the areas?
or put all the fittings on then try bog and sand around them in one hit?
or is it "6" one way 1/2 doz the other?
so far iv done it one way on the main hull and the other on the beams, both ways seem a pain in the ass....
