14m carbon wing mast, bare tube, new
From what I understand the profile is the same as used on the TP52's (wing section is 250mm x 118mm)
Weight is 51kg at 14m, and it is a bare tube so all spreaders/fittings/track etc have yet to be fitted.
I am no expert on masts, but would assume that (as its specs are strong enough for high loads on a 32' trimaran) it would be more than strong enough for a 10m monohull. I am sure Hallspars could quote you for a fitout.
