all fired up 6 Posted August 27, 2014 Share Posted August 27, 2014 I will be fitting a marine toilet to the yacht sometime in September. Do the forum members have any suggestions as to the best type of through hull valve to use and where I can source two? a.f.u Link to post Share on other sites
S.M.U. 15 Posted August 27, 2014 Share Posted August 27, 2014 TruDesign Marine Ball valve BSP thread with same brand thru hull, reinforced plastic, made in NZ and should be available in your nearest yacht shop. These are goooooooood kit. Link to post Share on other sites
Island Time 1,222 Posted August 27, 2014 Share Posted August 27, 2014 Agreed with above. BUT, have you considered one of the new composting toilets? Nature's Head, or Airhead? No throughhulls required, no holding tank, no issues about discharge,as there isn't any! If I was to replace one of my marine toilets, I'd seriously look at these. http://natureshead.net/marine.html or https://www.airheadtoilet.com/ Link to post Share on other sites
Glsssbead 2 Posted August 28, 2014 Share Posted August 28, 2014 Take a look at fairfit valves - also made in NZ. I haven't had any issues with mine though they were 25 years old, so I just replaced them with new ones as a best practice. http://www.fairfit.co.nz/page10.htm Link to post Share on other sites
Guest Posted August 28, 2014 Share Posted August 28, 2014 + 1 for Trudesign Link to post Share on other sites
waikiore 398 Posted August 29, 2014 Share Posted August 29, 2014 If you must go plastic, or more correctly Marelon or one of the other glass reinforced nylons, look at Hansen fittings, last I checked the tru-design valves were not full bore. I E the skin fittings and ID of the ball valves must be full diameter, no point having an 1 1/2" bsp valve (all manual marine toilets) and skin fitting if the id of the ball valve is just over an inch! These things are crucial on engine raw water intakes and exhausts and toilet outlets for a trouble free life. Link to post Share on other sites
Guest Posted August 29, 2014 Share Posted August 29, 2014 Anyone got any issues with those Fairfit valves? I have 2 holes to fill and like those as long as they are reliable and stand the test of time. Link to post Share on other sites
S.M.U. 15 Posted August 29, 2014 Share Posted August 29, 2014 If you must go plastic, or more correctly Marelon or one of the other glass reinforced nylons, look at Hansen fittings, last I checked the tru-design valves were not full bore. I E the skin fittings and ID of the ball valves must be full diameter, no point having an 1 1/2" bsp valve (all manual marine toilets) and skin fitting if the id of the ball valve is just over an inch! These things are crucial on engine raw water intakes and exhausts and toilet outlets for a trouble free life. Very true Waikiore but I thought all Hansen Valves were BSPT as opposed to True Designs BSP which can make it a bit awkward if you don't have a BSPT thu hull. Link to post Share on other sites
Chewing Gum 17 Posted August 30, 2014 Share Posted August 30, 2014 Hansen valves are great and fit the standard skin fitting threads whether bronze or plastic. We have some that are still good after 10years. Myself, I am nervous about plastic skin fittings and stick with the bronze. We use a lectrasan system , can't be bothered with holding tanks. Link to post Share on other sites
too_tall 15 Posted August 30, 2014 Share Posted August 30, 2014 Hansen stuff is as tough as hell and lasts very well and of course no need to tie it to you earthing system. The through hull type of tank glands they make are good too. Link to post Share on other sites
Optional Extra 0 Posted September 2, 2014 Share Posted September 2, 2014 Is FAIRFIT the only skin fitting/ball valve on the market that is flush against the hull when closed? Link to post Share on other sites
S.M.U. 15 Posted September 2, 2014 Share Posted September 2, 2014 Is FAIRFIT the only skin fitting/ball valve on the market that is flush against the hull when closed? FORESPAR Flowtech Valve System is an alternative for the weight conscious but the shiny Fairfit is so appealing. The more shiny bits the better so on those rainy days you can polish your toilet valve Link to post Share on other sites
Guest Posted September 2, 2014 Share Posted September 2, 2014 If you google sphincter + polish you get zwieracz. I'm not quite sure why I did that. Those Poles sure have hard to pronounce words. Link to post Share on other sites
rossd 16 Posted September 2, 2014 Share Posted September 2, 2014 Trudesign gear is made with 2 different thread forms we use BSP generally and NPS is also made for the US market I guess. There is something fishy about there bore sizes as waikiore says. I think some cost cutting measures are going on. I brought 2 different sized valves but on inspection at home the balls inside were the same size, the only difference was the thread size. So the larger valve has a restrictive ball. (Does that sound right!) Link to post Share on other sites
Guest Posted September 2, 2014 Share Posted September 2, 2014 NPS is a nightmare for anybody outside the US. Best stick with BSP but then you've got to decide between parallel and taper. Most thru hulls I have seen are parallel so a parallel thread valve needs to be fitted. Then the outlet hose nipple will generally be BSP taper. Not such a big deal in synthetic fittings but a problem with bronze and stainless. Link to post Share on other sites
