smithy09 50 Posted June 2, 2016 Share Posted June 2, 2016 The Marshall has a few carbon bits outside that are deteriorating and the outer coat is pealing off. How do you prepare and re-coat this? Is there a special UV resistant epoxy? Can you just sand it back then brush on the resin? Any advise appreciated! Thanks. Quote Link to post Share on other sites
Marshy 30 Posted June 2, 2016 Share Posted June 2, 2016 I can check with FOC but i think they were Durapox'd to start with - so a light sand back and re-coat... Quote Link to post Share on other sites
smithy09 50 Posted June 2, 2016 Author Share Posted June 2, 2016 Thanks Guys. Quote Link to post Share on other sites
smithy09 50 Posted June 8, 2016 Author Share Posted June 8, 2016 2 pot polyurethane according to Adhesive Technologies, so that's what they are getting!! Before and after shots.. 1 Quote Link to post Share on other sites
1paulg 17 Posted June 8, 2016 Share Posted June 8, 2016 Interesting - is that as UV resistant to the underlying carbon as opposed to putting a 2 pot white on ? Quote Link to post Share on other sites
Clipper 343 Posted June 8, 2016 Share Posted June 8, 2016 What brand did you use? Quote Link to post Share on other sites
smithy09 50 Posted June 8, 2016 Author Share Posted June 8, 2016 Interesting - is that as UV resistant to the underlying carbon as opposed to putting a 2 pot white on ? No idea Paul. Just the answer I got from the guys at Adhesive technologies. Who wants white anyway???? Bling rules!! Quote Link to post Share on other sites
smithy09 50 Posted June 8, 2016 Author Share Posted June 8, 2016 What brand did you use? International Perfection plus. I asked about using 207 West system hardener which is UV resistant but they reckoned 2 pot polyurethane was better.. Quote Link to post Share on other sites
Battleship 100 Posted June 8, 2016 Share Posted June 8, 2016 Awlood ma works really well,should outlast perfection especially on something that is subject to a bit of flex, a bit pricey mind you. Quote Link to post Share on other sites
mattm 98 Posted June 8, 2016 Share Posted June 8, 2016 Paul- I got a Gennaker prod from Ctech about a year ago. I asked for clear coat and they said they don't recommend it as the carbon won't last as long, and gave me a choice or black or white. I clear coated a mast a few years before that and was recommended a Carboline product as providing the best uv available in clear, sold the boat before I really got to find out, seemed pricey also. Quote Link to post Share on other sites
Changed 10 Posted June 9, 2016 Share Posted June 9, 2016 Durapox clear? Quote Link to post Share on other sites
smithy09 50 Posted June 9, 2016 Author Share Posted June 9, 2016 Awlood ma works really well,should outlast perfection especially on something that is subject to a bit of flex, a bit pricey mind you. Perfection wasn't cheap!! Quote Link to post Share on other sites
1paulg 17 Posted June 9, 2016 Share Posted June 9, 2016 KM - think your are right - it is the resin that breaks down. I have a carbon rig that is 10 yrs old and painted white and looks mint - if it is an item that is easy to redo and you want bling then clear cote is fine but for bigger items like a rig I wouldn't take the chance.. Quote Link to post Share on other sites
wheels 543 Posted June 13, 2016 Share Posted June 13, 2016 Yep it's just Carbon. If you put it under a lot of pressure while applying a lot of heat, you will end up with a Diamond. Quote Link to post Share on other sites
Marshy 30 Posted June 13, 2016 Share Posted June 13, 2016 dont tell any raceboat owners wife that or the country will run out of heatguns and clamps!! 1 Quote Link to post Share on other sites
