Advice for painting an alloy mast
Does anyone have a view on the best way to paint an un-anodised aluminium mast?  Not a big job as its for a 65 year old classic sailing dinghy that spends most of its time under cover or sailing on fresh water.
I have had advice to just wash the mast with turps and then water and dry, then apply a water-based galv iron primer and enamel top coat.  Is this enough given the mast has a pretty benign life or is it worth going to more complicated two-pot solutions?
While protecting the mast is a factor, a key reason for painting it is appearance (the boat has a wooden mast which comes out for special events but it is so heavy it is a major to step it singlehanded) so the top coat on the alloy version is likely to be in a brownish colour that from a distance will look like wood!
thanks
General rule of thumb is, the more effort spent, the longer it will last.
If you want cheap and easy, sand back, then detergent wash and then apply PA10 as a primer, then your topcoat of choice.
The longer lasting hard wearing coatings need good prep etc and then an etch primer and desired two pot top coat.
Thanks Wheels - was thinking PA10 could be a good way to go as a practical mid-course among the options.  Given the mast has never been painted, after a good clean/degrease, what grade sandpaper would you reecommend to roughen the surface prior to paint application?  Thanks.
I also got my alloy mast (30' keeler) sand blasted and painted by Rudolph's a few years ago. They did a great job and the epoxy coating still looks great. Adequate preparation is the key to success for any coating system.
Sand blasting can be OK if the Guy is experienced. But Aluminium can be damaged really easily if you get someone that has no clue.
Sandpaper Grit size, 240 is fine. It is essential to give it a good clean with Acetone and get the PA10 on it as quickly as you can. Do leave it for Days or Hrs even.
Isn't it usual to use a 2 pot etch primer followed by 2 pot polyurethane on aluminium ?
If prep is not good the paint will definitely fall off leaving an unsightly mess. If unpainted my preference would be to leave it that way.
going through the same thing with a corroding boom
easiest thing seems to be clean up as best possible, then oil paint with silver enamel
- it'll look better
- the rate of corrosion will at least be slowed
- if silver paint flakes off silver alloy it doesn't stand out much
