KJT 1 Posted August 22, 2016 Share Posted August 22, 2016 I have a 32 ft cat. Having problems with weather helm and rudder stalling at over 15 knots. I thought after lengthening the boat, and moving the rudders further aft, the balance on a reach would improve. Any suggestions? One I already have in mind is adding a prod to get the reacher further forward. Currently tacked down on ropes from the bows. Fence? Quote Link to post Share on other sites
Island Time 1,232 Posted August 22, 2016 Share Posted August 22, 2016 I'd expect the issue is ventilation or cavitation. Ventilation is when air is sucked down the side of the rudder casing the rudder to let go. It can sometimes be fixed with ventilation plates. Cavitation is when the pressure on the LP side of the rudder is so low that the water effectively boils - also causing the rudder to let go. So, depending on when this happens (Not just speed but also rudder angle) the solutions might be different. Is it only with large rudder angles? It may be that the foil section is not a good one for the use it has, or the shape is not perfect? Anyway. perhaps TC or someone else with more knowledge than me might chip in? Quote Link to post Share on other sites
KJT 1 Posted August 22, 2016 Author Share Posted August 22, 2016 Hi It is with large rudder angles. Have to put up to 20 25 degrees to counter the helm. Which is why i suspect it is stalling. Losing the flow attachment. Section is as per the original design by Ron Given. Looks close to NASA 0012. I'd expect the issue is ventilation or cavitation. Ventilation is when air is sucked down the side of the rudder casing the rudder to let go. It can sometimes be fixed with ventilation plates. Cavitation is when the pressure on the LP side of the rudder is so low that the water effectively boils - also causing the rudder to let go. So, depending on when this happens (Not just speed but also rudder angle) the solutions might be different. Is it only with large rudder angles? It may be that the foil section is not a good one for the use it has, or the shape is not perfect? Anyway. perhaps TC or someone else with more knowledge than me might chip in? Quote Link to post Share on other sites
ScottiE 174 Posted August 22, 2016 Share Posted August 22, 2016 Which boat is this KJT? Quote Link to post Share on other sites
Island Time 1,232 Posted August 22, 2016 Share Posted August 22, 2016 Yep. I'd expect it's doing all it can. Flow will become detached at an angle of attack too large for the speed. The issue is likely not the rudder at all - but the balance of the boat - you should not need large rudder movements at high speed. Losing flow attachment is caused by one of the two reasons I mentioned above. What point of sailing is this normally on? What is the attitude of the boat (Level, leeward bow down etc). I'm no multi specialist, but I suspect that the most benefit could be gained from rig setup and sails, to try to reduce the weather helm at speed ?? Quote Link to post Share on other sites
Ed 143 Posted August 22, 2016 Share Posted August 22, 2016 Weather helm... so the boat is trying to round up on you? Try putting a bit more board down. If its lee helm, with the boat wanting to bear away all the time, lift a bit of board up Quote Link to post Share on other sites
KJT 1 Posted August 22, 2016 Author Share Posted August 22, 2016 Yep. I'd expect it's doing all it can. Flow will become detached at an angle of attack too large for the speed. The issue is likely not the rudder at all - but the balance of the boat - you should not need large rudder movements at high speed. Losing flow attachment is caused by one of the two reasons I mentioned above. What point of sailing is this normally on? What is the attitude of the boat (Level, leeward bow down etc). I'm no multi specialist, but I suspect that the most benefit could be gained from rig setup and sails, to try to reduce the weather helm at speed ?? Hi Boat sails level. 3 sail reaching with genoa and drifter/reacher. Control is OK up to about 14 knots then it starts to require too much rudder. Rounding up. Boards are all the way down. Most of the fleet has prods so wondering about setting up the spinnaker pole with water-stays from the bows, as a prod, for the reacher, to get the centre of effort further forward. With the end on the front of the bridgedeck through the anchor fairlead. I am putting up some photos of the boat on the Gallery. Quote Link to post Share on other sites
Island Time 1,232 Posted August 22, 2016 Share Posted August 22, 2016 Is the boat properly flying a hull at that point? How much heel? Is your mast rake too much? Or board design, position and rake? Main in too tight? If you drop the main to leeward a bit more than normal, does that help? Playing with the main will give you an indication as to if this is a trim/balance issue. If it still does it with the main really off, then it will be hard to fix with sails... Get one of the top cat sailors to come out with you and have a look... any volunteers here? Quote Link to post Share on other sites
w44vi 17 Posted August 22, 2016 Share Posted August 22, 2016 How full is the main, out haul fully out ? Cunningham on? Is the kicker tight or eased? Quote Link to post Share on other sites
Freedom GBE 27 Posted August 22, 2016 Share Posted August 22, 2016 15 knots is not slow. A prod should do the trick. Drive it like you stole it, screecher on a prod definitely increases things going bad as in stressing, breaking things. Also need an expensive furler. Screechers also have a narrow window where you can use it. But if you want to get in before dark on the coastal classic you will want a screecher. If you don't have a prod I assume you don't have a genaker? You definitely need a large genaker. I usually enjoy a send on a kite more than the angle of death on a screecher. Quote Link to post Share on other sites
KJT 1 Posted August 22, 2016 Author Share Posted August 22, 2016 Which boat is this KJT? Dawn Treader. See photos in Gallery. Quote Link to post Share on other sites
KJT 1 Posted August 22, 2016 Author Share Posted August 22, 2016 Yep. I'd expect it's doing all it can. Flow will become detached at an angle of attack too large for the speed. The issue is likely not the rudder at all - but the balance of the boat - you should not need large rudder movements at high speed. Losing flow attachment is caused by one of the two reasons I mentioned above. What point of sailing is this normally on? What is the attitude of the boat (Level, leeward bow down etc). I'm no multi specialist, but I suspect that the most benefit could be gained from rig setup and sails, to try to reduce the weather helm at speed ?? Boat is level when sailing. Bow up at rest. Quote Link to post Share on other sites
KJT 1 Posted August 22, 2016 Author Share Posted August 22, 2016 Is the boat properly flying a hull at that point? How much heel? Is your mast rake too much? Or board design, position and rake? Main in too tight? If you drop the main to leeward a bit more than normal, does that help? Playing with the main will give you an indication as to if this is a trim/balance issue. If it still does it with the main really off, then it will be hard to fix with sails... Get one of the top cat sailors to come out with you and have a look... any volunteers here? Thanks. Just starting to lift the hull. Quote Link to post Share on other sites
KJT 1 Posted August 22, 2016 Author Share Posted August 22, 2016 How full is the main, out haul fully out ? Cunningham on? Is the kicker tight or eased? Main was probably too full. Just got it recut after last sail. Sails are all from the early 80's when the boat was a race boat. Can't test it at the moment as on crutches. Quote Link to post Share on other sites
ScottiE 174 Posted August 22, 2016 Share Posted August 22, 2016 A cat on crutches - that's a terrible thing! Quote Link to post Share on other sites
KJT 1 Posted August 22, 2016 Author Share Posted August 22, 2016 15 knots is not slow. A prod should do the trick. Drive it like you stole it, screecher on a prod definitely increases things going bad as in stressing, breaking things. Also need an expensive furler. Screechers also have a narrow window where you can use it. But if you want to get in before dark on the coastal classic you will want a screecher. If you don't have a prod I assume you don't have a genaker? You definitely need a large genaker. I usually enjoy a send on a kite more than the angle of death on a screecher. I only need to add a couple of eyebolts at the waterline to try the spin pole as a prod. Have a broken angle so will not be able to experiment for a bit. The drifter/reacher is 3oz dacron with a wire luff. Set from a tack line between blocks on the bows. Works from a tight reach to downwind and up to 25 knots wind on a broad reach. I have a light air symmetrical spinnaker as well. All sails are from the first iteration of the boat in 1985. The main, jib and genoa are the only ones that have had a lot of use. As the drifter/reacher puts us into double digits in moderate winds i want to set it up to work properly. We have now recut the main so should be a bit flatter. New sails are not an option at this stage. Wife wants new kitchen. She has been waiting patiently until i have the boat sailing, so fair enough. Quote Link to post Share on other sites
KJT 1 Posted August 22, 2016 Author Share Posted August 22, 2016 A cat on crutches - that's a terrible thing! less likely to go over when flying a hull.LOL Quote Link to post Share on other sites
