Kevin McCready 83 Posted June 15, 2017 Share Posted June 15, 2017 The future is clearly here for some people. The oar comparison was funny but unfair. Since I'm of the sailing variety of sailors and retired there's rarely a reason to rush somewhere under power. I'm looking forward to my next boat now. Any takers for this one? Special deal for crew forum members or their friends or their relatives or ... http://www.trademe.co.nz/Browse/Listing.aspx?id=1347514608 Quote Link to post Share on other sites
wheels 543 Posted June 15, 2017 Share Posted June 15, 2017 Actually chatting to the dude who sells genuine fully electric systems and top end EU made ones, he reckons 'great for weekends, sh*t for cruising'. When asked why he said 'Sunday night you plug your boat into the mains, something you can't do at Minerva reef'. Pure electric has one big problem they have yet to crack, re charging the batteries. That's what I keep saying. Weekender is fine, because you can plug in. Cruising...forget it. It doesn't matter even if an electric system was cheap as chips. If you can't get the energy consumed back into the bank, you are wasting your time. Very simply, the amount consumed could never be replenished in a ideal time frame. One would need far to large an area of Solar panels. Wind does not produce enough power unless you are on a cyclone and a towed gen is no better and the drag is large. The greatest amount of stored energy available to us in a small volume is Diesel fuel. For the future, forget battery stored power. An electric motor does indeed have some huge advantages. It is the storing of the energy and the replenishing of that energy that is the current issue. Storage is and will continue to improve and become cheaper, but the replenishing will always be the issue. So for the future, we need to look toward Fuel Cells. A Fuel Cell is the ability to take a "fuel" and convert directly to electrical energy. It has the greatest efficiency and the plus of storing a high volume of energy in a very small space. At the moment, fuel cells are expensive to run because of the fuel used. Either Ethanol or Hydrogen. But someone will come up with something eventually I am sure. It's kind of like the poor cousin to Cold Fusion, where every Home has a "Mr Fusion" in the Garage providing the Homes energy needs. Quote Link to post Share on other sites
chariot 242 Posted June 15, 2017 Share Posted June 15, 2017 A bit of a cost comparison. 30hp diesel $14,500 + $7,000 for removal of old engine and fitting new. Pretty much the same as above for all new setup. Quote Link to post Share on other sites
too_tall 15 Posted June 16, 2017 Share Posted June 16, 2017 With regard to the relative thrust of same sized internal combustion vrs electric motors, the electric at say, 20hp will have a more consistant ability do deliver 20hp. A 20hp internal combustion motor requires correct propping ( as that 20hp only occurs at a narrow band of the rev range, wereas the electric will be over a wider range ) and to operate at 20hp its operating at full load - and probably will get heating issues if its really at its power output limit. The electric motor at 20hp is operating at its rated power output, and will do so until it runs out of joules to chew on. So whilst you may get away with a 20hp electric outboard, you may well not be able to get away with a 20hp electric. As has been mentioned several times, the electric options simply have such inferior range, or, they require such a huge amount of battery capacity AND charging that the technology is just not mature enough as of yet. Quote Link to post Share on other sites
Myjane 40 Posted June 16, 2017 Share Posted June 16, 2017 Black panther you would have to be joking going electric with all the solar gear needed to power what one uses the boat would start looking like a space ship with panels every where Quote Link to post Share on other sites
Black Panther 1,568 Posted June 16, 2017 Share Posted June 16, 2017 I havent looked into it in depth coz my current engine is working just fine. If it died would i investigate electric? Yes. Would i accept a drop in range and performance for the advantages of electric? Yes. As long as i was putting a surplus into the system while at anchor it is worth a look. That means at a dock you are charging at anchor you are charging and under sail you are charging. Only questions to answer are maximum range (25hrs at 4 kn fine) and rate of recharge which i would express as ratio of time charging to time motoring. Answer will be different for anchored and under sail. Quote Link to post Share on other sites
Myjane 40 Posted June 17, 2017 Share Posted June 17, 2017 apart from the propulsion thing there is living power , we find cruising Leave Marina 100/. Percent , 300 amps two 80 watt solar panels , day one ok , day three power settles at 80 percent and stays there , run engine each day helps , usually after a week the power in storage is average is 80 percent , radio , fridge , lights at night , vhf , and occasionally at night the DVD video , this power has to be put on top Of an electric motor and its battery's so it gets complicated. Many battery's. House ,engine , it goes on Quote Link to post Share on other sites
Black Panther 1,568 Posted June 17, 2017 Share Posted June 17, 2017 That sounds very interesting km. Ill have to get to the office to open the link and have a closer look. My engine is a nissan pathfinder. Can never remember if it 65 or 85 hp. Adequate. 7 kn in flat water and a clean bum. I can fit 450 watts of solar easy on the new bimini . Plan was to wait and see if thats enough before adding something. If i ever decide to go electric drive that would include a grunty water generator. Quote Link to post Share on other sites
Black Panther 1,568 Posted June 17, 2017 Share Posted June 17, 2017 Boat weighs 12 tonne according to Mr Spencer Quote Link to post Share on other sites
Black Panther 1,568 Posted June 17, 2017 Share Posted June 17, 2017 Could probably squeeze that 600w wiithout it getting ugly. More than enough for domestic purposes. If add an electric drive add a windmill and a water generator then do the sums. If i could even get 10:1 under sail id consider it Quote Link to post Share on other sites
Myjane 40 Posted June 17, 2017 Share Posted June 17, 2017 You could form a roof of a dog house with panels , or have Flexi panels made Quote Link to post Share on other sites
Myjane 40 Posted June 17, 2017 Share Posted June 17, 2017 Check out glen damatos boat Valkyrs hard dodger the photos show covered in solar film delivering power . Quote Link to post Share on other sites
Black Panther 1,568 Posted June 17, 2017 Share Posted June 17, 2017 Mj i can get that 600w by wandering down the road and buying standard panels and putting them on top of my existing bimini. Would barely notice them Quote Link to post Share on other sites
Myjane 40 Posted June 17, 2017 Share Posted June 17, 2017 600 wt is six 1200 x600 panels Quote Link to post Share on other sites
Black Panther 1,568 Posted June 18, 2017 Share Posted June 18, 2017 five x 120. I've checked. Quote Link to post Share on other sites
Myjane 40 Posted June 18, 2017 Share Posted June 18, 2017 That's if they are end on , I have bolted two together so I have 1200 x1200 on a frame and that forms another dry area at the back of the cockpit Quote Link to post Share on other sites
Black Panther 1,568 Posted June 20, 2017 Share Posted June 20, 2017 Here's a candidate http://www.trademe.co.nz/motors/boats-marine/yachts/other-yachts/auction-1353022238.htm Quote Link to post Share on other sites
cj! 19 Posted July 2, 2017 Author Share Posted July 2, 2017 Just thought I'd add these links to a two part series 'The Science of Hybrid Propulsion' by Nigel Calder comparing series and parallel hybrid propulsion options with diesel and the efficiency crossover points. With the continuing drop in LiFePO4 pricing, the potential is starting to look a little better as that should bring the crossover point up a bit again, especially if you're not chasing high cruising speeds. https://www.passagemaker.com/technical/hybrid-science-part-1 https://www.passagemaker.com/technical/the-science-of-hybrid-propulsion-part-2 1 Quote Link to post Share on other sites
rigger 47 Posted July 2, 2017 Share Posted July 2, 2017 600 wt is six 1200 x600 panels five x 120. I've checked. What sort of panels are you looking at? Might have it wrong and they are probably not be suitable for onboard but LG do panels that are 300w, 1016mm x 1686mm. similar area to the 6 panels Myjame described. Recently installed a PV array at home - if anyone is interested I can provide further info on the performance of the setup - 10 x 285w panels - similar size to the ones mentioned above. Quote Link to post Share on other sites
Myjane 40 Posted July 2, 2017 Share Posted July 2, 2017 Go to M power on the shore they are solar pros and battery experts and priced good , best deal I could find and help Quote Link to post Share on other sites
