Winch maintenance
Hi I am about to do some overdue maintenance on my winches (Barient 24)  Any suggestions where i could buy the necessary pawls and spring? Is it possible to use Lewmar  pawls and springs?
Any help greatly appreciated
it's the size of the pawls + springs that matters more than who makes them
fortunately most seem somewhat standardised into big + littel
so take in whatever you find
and compare it with whatever is being sold
it's a very simple mechanical process and fine tolerances are not needed
most owners over-grease winches in the hope that that will enable under-servicing
doesn't really work like that as over greased winches become gummed up when the excess dries out
soaking gummed bits in kero or diesel and tackling with a toothbrush works well
on reassemble you're normally looking at a white lithium grease on the winch spindle and gear teeth but machine oil on the pawl + pivot
good videos on youtube by makers like lewmar etc
https://www.youtube.com/results?search_query=marine+winch+servicing
The stuff out of the lewmar winch grade pack looks and feels remarkably like bog standard ep2 Grease. A bit of 3 in one oil for the pawls as Eric suggests and you'll be fine. Servicing winches 6 monthly or yearly is easy. Every 5 years takes a lot longer!
