strath 4 Posted April 11, 2018 Share Posted April 11, 2018 Hi I am pulling out on Monday next, for a bottom scrape. I have previously used Alex No10 ( light grey colour) I want to go back to a softer ablative antifouling and have use Altex No5 before. However I would like stay with the light grey colour but Altex No5 only comes in Red, Black or Blue. The boat is on the marina at Gulf Harbour. So I would like some feedback on Warpaint light grey colour please. Strath Quote Link to post Share on other sites
S.M.U. 15 Posted April 12, 2018 Share Posted April 12, 2018 My understanding that War is older technology but still has a loyal following. Another choice is international micron xtra 2 in dover white, has been known to out perform more expensive product up here in the north, but it is very soft. Quote Link to post Share on other sites
wheels 543 Posted April 12, 2018 Share Posted April 12, 2018 There is not really any " older technology" as such. But it is a " price point" AF. Some get good results and others not so good. And that is the same for every AF on the market. The hard part is getting one that works best for your area. Water quality, temperature, current etc etc all play a part in how well they all work. Quote Link to post Share on other sites
Battleship 100 Posted April 12, 2018 Share Posted April 12, 2018 Use it and like it. Don't expect it to work well after about 12 months it's been on one of the boats for over 2 years and has pretty much stopped working, but could probably be revived with a sand. It is very.nice to use and seems a lot less toxic than the international stuff. Quote Link to post Share on other sites
ScottiE 174 Posted April 12, 2018 Share Posted April 12, 2018 . . . and seems a lot less toxic than the international stuff. you've drunk both? Quote Link to post Share on other sites
waikiore 399 Posted April 12, 2018 Share Posted April 12, 2018 Its not soft you will have to scrub it unlike no. 5 Quote Link to post Share on other sites
Black Panther 1,586 Posted April 12, 2018 Share Posted April 12, 2018 you've drunk both? These multi sailors are seriously hard core Quote Link to post Share on other sites
Battleship 100 Posted April 12, 2018 Share Posted April 12, 2018 No just used both, international antifoul makes me seriously crook. Warpaint no so much. The thinner they sell to use with it just seems to be turps. Quote Link to post Share on other sites
armchairadmiral 411 Posted April 12, 2018 Share Posted April 12, 2018 You get what you pay for with a/f. Micron 66 is more expensive up front but a lot cheaper overall because it lasts much longer than,say, Warpaint which we've used in the past. But get it sprayed. Much better finish than roller / brush ! Quote Link to post Share on other sites
Battleship 100 Posted April 12, 2018 Share Posted April 12, 2018 Depends who is doing the job a lot. But yes generally spraying is a better finish. I have seen shocking examples of both. Got it sprayed last time and needed twice as much paint. When you.add in the cost of the application rolling is better for non race boats in my humble opinion. You can always give it a quick wet and dry if you want a super smooth finish. Quote Link to post Share on other sites
ex TL systems 63 Posted April 12, 2018 Share Posted April 12, 2018 Pretty sure it will stick like peanut butter to a blanket, old antifoul is hardly a perfect surface but the new stuff always seems to stick ok Quote Link to post Share on other sites
marinheiro 352 Posted April 12, 2018 Share Posted April 12, 2018 You get what you pay for with a/f. Micron 66 is more expensive up front but a lot cheaper overall because it lasts much longer than,say, Warpaint which we've used in the past. But get it sprayed. Much better finish than roller / brush ! I have heard from one of the painters that they have changed the brew for Micron 66 and it is not as good as it used to be 1 Quote Link to post Share on other sites
ex TL systems 63 Posted April 12, 2018 Share Posted April 12, 2018 The label on warpaint says as long as it’s there it’s still working, I have stretched mine to 4 years with some scrubbing, seems the previous owner put on about 7 coats so I am going to try the same again with warpaint plus some nautical ablative on top. Will put on maybe 12 litres for a 38 ft cat . Quote Link to post Share on other sites
harrytom 642 Posted April 13, 2018 Share Posted April 13, 2018 I often looked at "war paint" but could never find a user ,Tried "Hempels" in Tamaki river but found to soft,went to "Altex 10" but no longer available. So thought about it and tried the "Altex coastal cruising" and found for an inexpensive paint it was working,applied in labour weekend 2017 and beginning of January looked new ,when yacht came out of water January there was only very slight slime,not bad for river,so guessing might of got 6 months before needing a clean but will never know now. Quote Link to post Share on other sites
Fogg 427 Posted April 13, 2018 Share Posted April 13, 2018 Micron 66 doesn’t work so well in gulf area now. I used it for 10yrs but noticed reduced performance so switched to even more expensive Micron Ultra. Quote Link to post Share on other sites
Battleship 100 Posted April 14, 2018 Share Posted April 14, 2018 Re-coated ours today, had been on about 28 months not barnacles but the slime and a bit of weed was starting to cling on a a lot quicker, put on light grey then mid grey so we know when its starting to wear, Warpaint is currently $180 for 4 litres. Close up of substrate after 28 months Finished. Quote Link to post Share on other sites
Battleship 100 Posted April 14, 2018 Share Posted April 14, 2018 That was rolled, waterblasted clean pretty easily then a wet sand with sanding screens and re-apply. Quote Link to post Share on other sites
ballystick 72 Posted April 14, 2018 Share Posted April 14, 2018 Would micron 66 go over sanded Copper epoxy? West with Current powder spheres. Probably a question for IP. I applied Micron 66 over Coppercoat with great results, good finish and it seemed to stay active for far longer than any subsequent recoats on our R930 Quote Link to post Share on other sites
ballystick 72 Posted April 15, 2018 Share Posted April 15, 2018 That was early Micron 66, subsequent coats didn't seem to have the same punch as far as staying clean. But adhesion and finish on the Coppercoat (which was next to useless) was great! Quote Link to post Share on other sites
splat 55 Posted April 15, 2018 Share Posted April 15, 2018 Funny....could never figure out why the boat has so many coats and colours....but starting to get older coat adhesion issues four colours below! Quote Link to post Share on other sites
