Rafin 2 Posted May 23, 2018 Share Posted May 23, 2018 Just wondering if anyone can offer some advice please, heading to Fiji, Vanuatu soon and have an older non GPS ipad2. Have downloaded Google Earth maps on and will run it through an iridium phone. Does anyone know if we can connect GPS to this iPad. Figure it would be a good extra to the Chartplotter. Thanks. Quote Link to post Share on other sites
Battleship 100 Posted May 23, 2018 Share Posted May 23, 2018 You can get a bluetooth gps unit for these. I might even have one somewhere you can use. You can then install navionics on the ipad as a backup chartplotter. Quote Link to post Share on other sites
Rafin 2 Posted May 23, 2018 Author Share Posted May 23, 2018 Thanks Will, I'll be in touch. Quote Link to post Share on other sites
Island Time 1,234 Posted May 23, 2018 Share Posted May 23, 2018 They have wifi. If you have wifi on the boat instruments, they can broadcast the gps data, and the ipad can use it. If not, you can load an app on your phone to share its gps data with the ipad, over Bluetooth or wifi. Quote Link to post Share on other sites
southernman 73 Posted May 24, 2018 Share Posted May 24, 2018 Yip easy to do if you have your oat instruments networked via wifi. I do that on our yacht. Quote Link to post Share on other sites
nagy592 21 Posted May 24, 2018 Share Posted May 24, 2018 If you want a backup, probably better to keep it separate from your boat's network. At least that is how I would do. Quote Link to post Share on other sites
Farina 2 Posted May 28, 2018 Share Posted May 28, 2018 Yes you can connect to GPS with an old ipad. You need a bad elf gps. [www.bad-elf.com]. That will connect you to GPS Satellites and GLONAS. what type of connection does your ipad have? if its the old original wide connection, I have a bad-elf that will fit. Quote Link to post Share on other sites
eruptn 95 Posted May 28, 2018 Share Posted May 28, 2018 Go the simple route, get the model with the inbuilt GPS chip set, why have add on bits and pieces. I've used a IPad mini as back up for the last 3 coastal classics and the Garmin Blue chart cartography. There is a good selection now available for the cartography. Works well down below, not designed for use at the helm. Gives you a nice simple stand alone backup. Preferred backup at the helm is a Garmin 78, fits nicely in the phone pocket of the wet weather gear, around 16 hours on 2 AA batteries. Quote Link to post Share on other sites
Rafin 2 Posted May 28, 2018 Author Share Posted May 28, 2018 Thanks for all the input guys. It's an old iPad with wide plug as a matter of interest. Anyway a simple resolution has been found, I am simply going to swap iPads with my son for the trip, his is flasher and GPS equipped. He is doing part of the trip with us so can make sure it works for me! Thanks again. Quote Link to post Share on other sites
John B 106 Posted May 30, 2018 Share Posted May 30, 2018 One of the greatest aids to navigation in recent history is google earth with your position plotted on it. Not so critical here but in the islands its a fantastic way of seeing how a reef structure works. So an Ipad or tablet with that on it is well worth the price of admission. Quote Link to post Share on other sites
