Ex Machina 365 Posted August 18, 2018 Share Posted August 18, 2018 Greetings folks I'm in the process of getting my boat up to cat 3 and I'm kind of stumped on how to make the coach roof sliding hatches lockable/unlock able from above and below with washboards in place . Keen to hear everyone's different setups . I'm sure there are some ingenious ideas out there Quote Link to post Share on other sites
Island Time 1,232 Posted August 18, 2018 Share Posted August 18, 2018 Lots of boats use a sprung bolt system that has a simple pull string on the inside, and can be locked outside. I use a door lock. $20 at Bunnings. Key outside, rotating knob inside. Washboards are also attached with lanyards, and a barrel bolt each side on the inside, so they can be individually locked in place if required. Never been an issue, up to cat 1 Quote Link to post Share on other sites
PeteG 13 Posted August 19, 2018 Share Posted August 19, 2018 +1 for the spring loaded barrel bolt thingy. We have ours on the inside to keep it out of the weather, and the pull string to the outside. We have perplex type washboards, so made up another set of ply ones that we set up to use for our storm washboards Quote Link to post Share on other sites
Ex Machina 365 Posted August 19, 2018 Author Share Posted August 19, 2018 Ok thanks for the ideas . I too have Perspex/acrylic washboards so have made ply ones in two parts because companion ways are below the shear line Quote Link to post Share on other sites
S.M.U. 15 Posted August 21, 2018 Share Posted August 21, 2018 https://cdn.shopify.com/s/files/1/1273/5189/products/DW4160PB.jpg?v=1511314562 Hopefully the above link takes you to fosters for the spring loaded catch, cool in all brass but expensive. Haven't found a cheaper version here but plenty on ebay etc. Quote Link to post Share on other sites
PeteG 13 Posted August 23, 2018 Share Posted August 23, 2018 Try second hand house parts type places, for barrel bolts. Quote Link to post Share on other sites
Ex Machina 365 Posted August 23, 2018 Author Share Posted August 23, 2018 Cheers Pete , Ive scoured the town to no avail . There's some cheap nasty ones on T me which will do I will only use them a couple of times a year Quote Link to post Share on other sites
jay 3 Posted August 25, 2018 Share Posted August 25, 2018 This is what I use: https://www.burnsco.co.nz/shop/rv/hardware/latches-catches-hooks/flush-pull-latch Made specifically for the task. Mounts on washboard and locks hatch into place, can be opened from inside & out. Comes in plastic if weight is important or stainless if not. Never had issues with it and Cat 3 inspector was happy. Quote Link to post Share on other sites
