Farrari 4 Posted October 6, 2010 Share Posted October 6, 2010 I found that one of my Genoa tracks was leaking over the weekend when I washed the deck down. I have pulled it up and notice the current sealant looks to be a relatively soft compound of some description. I was going to use a generic silicone sealant but figured I should ask those that know. Any advise on the best sealant to use? Link to post Share on other sites
Guest Posted October 6, 2010 Share Posted October 6, 2010 never use silicone on anything apart from your engine and even then treat it like poison Link to post Share on other sites
Guest Posted October 6, 2010 Share Posted October 6, 2010 Once it has gone hard there is nothing in this world that will stick to silicone (including more silicone). Link to post Share on other sites
rigger 47 Posted October 6, 2010 Share Posted October 6, 2010 Sika has a good product but I cannot remember the code. It is not a silicone. Link to post Share on other sites
wheels 543 Posted October 6, 2010 Share Posted October 6, 2010 Any Urathane Adhesive Sealant will work just fine. Remove the track and clean the old stuff away. Either tape edges and around the bedding area, or keep a rag and some WD40 or turps or Kero on hand. Apply plenty and push down into place with mounting bolts/screws. But no all the way home. Keep about the thickness of a match stick..ish and allow to cure overnight. Internally, the gunk will not have fully cured after the 24hrs. Now pull down full with the bolts and this will expand the gunk inside into a water tight seal that will last forever. Link to post Share on other sites
MrWolf 0 Posted October 6, 2010 Share Posted October 6, 2010 For that type of work use Sikaflex 291. When applying sealant to your genoa track. Cut the nozzle for a 3mm bead. apply the bead right around the outside of the hole apply some sika to the thread or bolt at the head end approx the thickness of the track and the deck. Do not overtighten the bolts as you go, nip the whole lot up, then go back and re tighten, this stops the goop from gooshing out in one place. Link to post Share on other sites
Farrari 4 Posted October 7, 2010 Author Share Posted October 7, 2010 Awesome, thanks guys. I'm doing the clean up now with the intention to relay the track over the weekend. Link to post Share on other sites
Guest Posted October 7, 2010 Share Posted October 7, 2010 It is worthwhile to check that no water has got into the core while you are about it. Link to post Share on other sites
MrWolf 0 Posted October 8, 2010 Share Posted October 8, 2010 Clean Up Sika 291 using Turps or White Spirit. Meths has a funny habit of affecting the cure of the Sika round the edges of the track. Link to post Share on other sites
tuffyluffy 76 Posted October 12, 2010 Share Posted October 12, 2010 The trick with Sikaflex is to put a dollop under your foot, and walk around the deck a few times before you start. Its going to happen, so you may as well get it over with early Link to post Share on other sites
wheels 543 Posted October 12, 2010 Share Posted October 12, 2010 The only problem with that is, you don't get that surprise when you turn around and think, Where the hell did that come from. Link to post Share on other sites
