strath 4 Posted September 4, 2019 Share Posted September 4, 2019 Hi I am after a gas fitter to replace my gas line in Azure ( Farr 1020) Any recommendations? Quote Link to post Share on other sites
Dtwo 157 Posted September 4, 2019 Share Posted September 4, 2019 Good luck getting a gas fitter anywhere near a boat. Quote Link to post Share on other sites
Island Time 1,233 Posted September 4, 2019 Share Posted September 4, 2019 DIY. Or be prepared to remove LPG from the boat, or pay $$$ to have a compliant system installed. Quote Link to post Share on other sites
marinheiro 352 Posted September 4, 2019 Share Posted September 4, 2019 Malcolm Pollard - Aquaplumb, 021950924 Quote Link to post Share on other sites
Fish 0 Posted September 4, 2019 Share Posted September 4, 2019 DIY. Or be prepared to remove LPG from the boat, or pay $$$ to have a compliant system installed. I'm curious, if you removed LPG from the boat, what would you use instead; Kero Diesel, Propane, and just get a jet boil? Price of a diesel cooker is probably worth more than the boat. Kero I don't know so much about the cost of stoves, always used one camping as a kid. I understand propane is popular on race boats, doesn't sound any safer than an LPG set up, and must be a hassle if you want to go cruising for longer than one cup of tea. Of course I'm ruling out electric with a genny as just hilariously silly (you need 230 volt to cook with don't you, can't get the current from a 12 v stove?) Question is in the context of NZ's aging NZ built cruiser racer fleet, not new euro imports (which should have new and compliant systems anyway, right) Quote Link to post Share on other sites
Beccara 25 Posted September 4, 2019 Share Posted September 4, 2019 Canisters are cheap too Quote Link to post Share on other sites
tuffyluffy 76 Posted September 4, 2019 Share Posted September 4, 2019 DIY. You can buy flexible LPG pipe and crimp it on myself. Quote Link to post Share on other sites
Island Time 1,233 Posted September 4, 2019 Share Posted September 4, 2019 LPG gas hose, and crimps are available at Burnsco. You can use a pair of carpenters pliers to do the crimps... Quote Link to post Share on other sites
Island Time 1,233 Posted September 4, 2019 Share Posted September 4, 2019 I'm curious, if you removed LPG from the boat, what would you use instead; Kero Diesel, Propane, and just get a jet boil? Price of a diesel cooker is probably worth more than the boat. Kero I don't know so much about the cost of stoves, always used one camping as a kid. I understand propane is popular on race boats, doesn't sound any safer than an LPG set up, and must be a hassle if you want to go cruising for longer than one cup of tea. Of course I'm ruling out electric with a genny as just hilariously silly (you need 230 volt to cook with don't you, can't get the current from a 12 v stove?) Question is in the context of NZ's aging NZ built cruiser racer fleet, not new euro imports (which should have new and compliant systems anyway, right) Quite a few boats now going with electric hobs, especially induction ones. You'll need a genset, or decent inverter with good charging systems though. New boats are not built to NZ standards, and, unless going into survey, no-one checks. Quote Link to post Share on other sites
Steve Pope 243 Posted September 4, 2019 Share Posted September 4, 2019 Quite a few boats now going with electric hobs, especially induction ones. You'll need a genset, or decent inverter with good charging systems though. New boats are not built to NZ standards, and, unless going into survey, no-one checks. I thought that the implication was that if something happened that involved insurance and the gas setup didn't comply, you might not have a happy outcome. Quote Link to post Share on other sites
Island Time 1,233 Posted September 5, 2019 Share Posted September 5, 2019 The legislation is no retrospective. So as long as it was ok when installed you should be ok....IMO. Quote Link to post Share on other sites
Dtwo 157 Posted September 5, 2019 Share Posted September 5, 2019 The Cat rules state that you must be compliant with the relevant gas code. AFAIK there is no way you would ever get a gas fitter to sign off the flexible connection to a gimballed stove, so it's all a crock of compliance crud. Quote Link to post Share on other sites
Island Time 1,233 Posted September 5, 2019 Share Posted September 5, 2019 The relevant one is the one that was in place when the boat was built. The later ones are not retrospective. Quote Link to post Share on other sites
Cantab 341 Posted September 5, 2019 Share Posted September 5, 2019 The problem is that it is now illegal to "do it yourself" and fixing up an old system suddenly activates the new rules. I went to two gas suppliers and two sellers of gas system components and equipment asking for the labels legally required on gas bottle compartments, none of them new what I was talking about. Unfortunately in realty there is no way near enough gas fitters in the country to ever keep up with making boats compliant, let alone ones that will come work on a boat. Seems that regulators aren't required to consider the practical implications of their new rules. I also recall two very significant blasts in the last year that by shear luck didn't kill anyone, both on recently installed certified systems, go figure. Like a lot of things in this country now, you do your best and hope nothing goes wrong or someone complains about you, its dam near impossible to be compliant at everything and actually have any money left to feed yourself. Quote Link to post Share on other sites
180S 20 Posted September 5, 2019 Share Posted September 5, 2019 Have been going down this track too, compliance for insurance. PIA My solution was to remove the gas tank from under the sink, remove all the gas hardware from my burnsco 2 element hob, then cut a hole In the top plate and insert the unit that Beccara posted. Works a treat, retained a gimballed element with safety rail and is enough to boil the billy. 2 Quote Link to post Share on other sites
bigal.nz 59 Posted September 5, 2019 Share Posted September 5, 2019 We have just been through it. Got gas fitter to replace all the hose with the plastic coated cope piping so boat meets ASNZ5601.2. Also had gas detectors fitted along with the new solenoid controller. Added drain for the gas locker. Price was not too bad as we did a lot of the prep work our selves and had the gas fitter do the fiddly bits and issue cert. Quote Link to post Share on other sites
gisywaterboy 3 Posted September 5, 2019 Share Posted September 5, 2019 Try NZ Shipwrights, works out of Gulf Harbour and is registered to do gas. Quote Link to post Share on other sites
marinheiro 352 Posted September 5, 2019 Share Posted September 5, 2019 The Cat rules state that you must be compliant with the relevant gas code. AFAIK there is no way you would ever get a gas fitter to sign off the flexible connection to a gimballed stove, so it's all a crock of compliance crud. should not be a problem, from 2.11.2 AS5601.2 (my underlining) In general, other than for hose assemblies between cylinders and regulators, hose assemblies shall be used only between the regulator and rigid piping, and between rigid piping and appliances. Flexible hose shall be one continuous length and as short as practicable for the intended application in order to prevent kinking and damage to the hose. Flexible hose inside a caravan or boat shall be accessible. The connection of hose assemblies to each other is not permitted. IT is correct when he says the regulations have not made the gas standards retrospective. Gas fitters are required to certify that the work they have performed on a gas installation complies with the current regs and this is where it gets a bit tricky, as they may for example refuse to connect a new hose to a gas califont. To my knowledge all the new imported boats have their gas systems upgraded to the current standards with a gas fitters certificate as they are being sold as "new" and hence must comply in full as a "new installation". Used imports will be a different story. Quote Link to post Share on other sites
Dtwo 157 Posted September 6, 2019 Share Posted September 6, 2019 should not be a problem, from 2.11.2 AS5601.2 (my underlining) In general, other than for hose assemblies between cylinders and regulators, hose assemblies shall be used only between the regulator and rigid piping, and between rigid piping and appliances. Flexible hose shall be one continuous length and as short as practicable for the intended application in order to prevent kinking and damage to the hose. Flexible hose inside a caravan or boat shall be accessible. The connection of hose assemblies to each other is not permitted. Thanks for that, good to know. What is your opinion if my boat is a 1977 vintage but rebuilt? I had no questions importing it and insurance has not asked either. Obviously I won't be shouting from the rooftops but I'm interested to know where I stand, Quote Link to post Share on other sites
marinheiro 352 Posted September 6, 2019 Share Posted September 6, 2019 Thanks for that, good to know. What is your opinion if my boat is a 1977 vintage but rebuilt? I had no questions importing it and insurance has not asked either. Obviously I won't be shouting from the rooftops but I'm interested to know where I stand, That's a curly one. I would think that as a minimum the boat should comply with the applicable standard at the time the yacht was imported. I feel it is best to take the same approach as my EWOF inspector inspector takes, is the system from a holistic view point safe, ie are flexible hoses of the appropriate material, gas bottle locker sealed from yacht's internal and ventilated externally, gas sniffer fitted, and does system pass a leak test. Quote Link to post Share on other sites
