Clipper 343 Posted October 21, 2019 Share Posted October 21, 2019 Can anyone tell me where to get wider pieces of boat cloth than 1m? Everywhere I google has rolls 1m wide, I need a bit wider, and dont want a join. Quote Link to post Share on other sites
mcp 32 Posted October 21, 2019 Share Posted October 21, 2019 Can anyone tell me where to get wider pieces of boat cloth than 1m? Everywhere I google has rolls 1m wide, I need a bit wider, and dont want a join. http://www.adhesivetechnologies.co.nz/Products/Fabrics/Biaxial/ Quote Link to post Share on other sites
Clipper 343 Posted October 22, 2019 Author Share Posted October 22, 2019 Thanks, but they have 1020mm only, some places seem to have 1270mm widths, hunting around at the moment (Will take longer to find then to just overlap and fair I suspect) Quote Link to post Share on other sites
Terry B 70 Posted October 22, 2019 Share Posted October 22, 2019 Hi, not sure what it is you're doing but you can overlap the 2 sheets of glass, epoxy then cut carefully down the middle - see link below. So you end up with a near perfect edge joint between the 2 sheets - and no hassle with all the fairing and filling the seams. apologies if I'm teaching you to suck eggs (as the old saying goes). https://www.westsystem.com/instruction-2/epoxy-basics/applying-woven-cloth-tape/ Quote Link to post Share on other sites
mcp 32 Posted October 22, 2019 Share Posted October 22, 2019 Thanks, but they have 1020mm only, some places seem to have 1270mm widths, hunting around at the moment (Will take longer to find then to just overlap and fair I suspect) When I click on that link they were all 1270mm wide and I have purchased it off them at 1270mm wide. Quote Link to post Share on other sites
Ed 143 Posted October 22, 2019 Share Posted October 22, 2019 If it's mission critical to have a 50" wide roll and you don't mind waiting a little while you could order from soller composites in the US and get it shipped Quote Link to post Share on other sites
Luigi Vercotti 7 Posted October 22, 2019 Share Posted October 22, 2019 Is this any use? https://shop.ifsl.co.nz/products/fibreglass-cloth Quote Link to post Share on other sites
Clipper 343 Posted October 23, 2019 Author Share Posted October 23, 2019 When I click on that link they were all 1270mm wide and I have purchased it off them at 1270mm wide. Yes, but not the 200gm cloth. Quote Link to post Share on other sites
Clipper 343 Posted October 23, 2019 Author Share Posted October 23, 2019 Hi, not sure what it is you're doing but you can overlap the 2 sheets of glass, epoxy then cut carefully down the middle - see link below. So you end up with a near perfect edge joint between the 2 sheets - and no hassle with all the fairing and filling the seams. apologies if I'm teaching you to suck eggs (as the old saying goes). https://www.westsystem.com/instruction-2/epoxy-basics/applying-woven-cloth-tape/ Thanks, that's a good idea, I've not tried that technique. Probably what I'll end up doing. I am just sheathing the outside of a very small dinghy, and a 1270mm wide bit would mean no overlaps. Quote Link to post Share on other sites
Luigi Vercotti 7 Posted October 23, 2019 Share Posted October 23, 2019 Is this any use? https://shop.ifsl.co.nz/products/fibreglass-cloth These people have 200g cloth at 1300mm (50") wide. Isn't this what you're looking for? 1 Quote Link to post Share on other sites
Clipper 343 Posted October 23, 2019 Author Share Posted October 23, 2019 These people have 200g cloth at 1300mm (50") wide. Isn't this what you're looking for? Its perfect, but im a tight arse and its 3x the price. Thanks for the link though. Quote Link to post Share on other sites
mcp 32 Posted October 23, 2019 Share Posted October 23, 2019 Yes, but not the 200gm cloth. Oh, sorry...I over looked that. Quote Link to post Share on other sites
Vorpal Blade 89 Posted October 23, 2019 Share Posted October 23, 2019 What about sanding a small recess where the join is. Quote Link to post Share on other sites
Terry B 70 Posted October 23, 2019 Share Posted October 23, 2019 Thanks, that's a good idea, I've not tried that technique. Probably what I'll end up doing. I am just sheathing the outside of a very small dinghy, and a 1270mm wide bit would mean no overlaps. Hi, I'm building a dinghy as well (at least I was until I buggered my back) and I found that link when I appear to have had the same issue as you. Haven't tried doing it yet - back's still not up to it - but if it's in the West System book of 'how to's' it must be a proven method. Good luck! Quote Link to post Share on other sites
