L00seM00se 28 Posted July 27, 2020 Report Share Posted July 27, 2020 I’ve got a few rusty spots on my trailer to clean up (mostly under the plank used to walk on when retrieving). I figure a good grind back to good metal and then some primer/paint. What’s the best product to use for this? I want to do it once, so not worried about saving pennies. Thanks Quote Link to post Share on other sites
harrytom 283 Posted July 27, 2020 Report Share Posted July 27, 2020 Just done a trailer with Hammerite,its like a rubber type paint,lasts about 5yrs,galvinising today is done too light,I know galv is done by weight but it nevers seems to last like galv on trailers 20yrs ago. Oh yeah the hammerite https://www.mitre10.co.nz/shop/hammerite-metal-paint-750ml-silver-grey/p/360894 jim s and L00seM00se 2 Quote Link to post Share on other sites
KM... 868 Posted July 27, 2020 Report Share Posted July 27, 2020 'Crown' brand cold galvanising, like 'CRC Zinc it' but works. $25 odd a spray can which do go quite a long way. It's what galvanisers themselves use to tidy up the odd blemish. L00seM00se 1 Quote Link to post Share on other sites
L00seM00se 28 Posted July 27, 2020 Author Report Share Posted July 27, 2020 Harry, that says to apply direct to rust...presume you can apply to non-rusted as well? I’ve also been told White Knight Rust Guard is good...at $200 a can you’d hope so! Quote Link to post Share on other sites
harrytom 283 Posted July 27, 2020 Report Share Posted July 27, 2020 I have done 2 boat trailers and works great,no sanding but wouldnt hurt to scuff rust,500ml goes along way.paint over any surface rust or not.gives a speckle finish. nephew trailer 25yrs old gets lots of use and original galv holding up,friends trailer 5yr old and yep wheres the galv??did mine a few yrs ago and lasted 5yrs with no rust sign,just done my current trailer,so i expect at least 5 yrs as well. L00seM00se 1 Quote Link to post Share on other sites
Jon 155 Posted July 27, 2020 Report Share Posted July 27, 2020 https://www.mitre10.co.nz/shop/international-pa10-grey-primer-1-litre-grey/p/359934 or this L00seM00se 1 Quote Link to post Share on other sites
marinheiro 167 Posted July 27, 2020 Report Share Posted July 27, 2020 I would use Fertan on the bare steel as the base for other products https://www.mitre10.co.nz/shop/fertan-rust-converter-250ml/p/360278 L00seM00se 1 Quote Link to post Share on other sites
SanFran 6 Posted July 28, 2020 Report Share Posted July 28, 2020 Can you use these products on anchor chain. Have some rust starting to appear which id like to keep on top of. Anyone had success with this type of application? Quote Link to post Share on other sites
Abel Seaman 11 Posted July 28, 2020 Report Share Posted July 28, 2020 I built the trailer for my 26 ft trailer yacht from 125x 65 channel iron for 2 reasons: 1 the steel didn't cost me anything. 2 I had it shot blasted and zinc sprayed with the arc spray process. There is no dip bath in nelson so saved a trip to Christchurch too. Comparable cost. I used to get stuff shot blasted and zinc sprayed for industrial outdoor steel work so i had practical experience with it. Its a great technique as long as you have open sections like channels. Done right its as good as dipping, but probably not for chain. Thing is it would also be great for touch ups although the company that did my trailer had a minimum $100 charge. I had heard that Hammerite was a shadow of its old self as original formulation components are now not able to be used. Is this true? Engineering wisdom is that wire brushing and even needle gunning is not a substitute for proper shot blasting, and like all things to do with coatings its the surface preparation that counts! Quote Link to post Share on other sites
ex Elly 58 Posted July 29, 2020 Report Share Posted July 29, 2020 For anchor chain it probably wouldn't last long. Better to get your chain regalvanised, then it will look like new, but lose some of its strength (maybe 20%). Go to these guys: http://www.easttamakigalvanizing.co.nz/ Quote Link to post Share on other sites
