Dan 0 Posted December 14, 2020 Share Posted December 14, 2020 I am looking at a Lotus 9.5 that is on the market in the USA at the moment. Unfortunately, I reside in Canada so I am unable to inspect the vessel due to border restrictions during this COVID thing. So, I am wondering if someone can provide me with some rig dimensions since I can’t seem to find any on the internet. Sailboatdata has a fair amount of info, but none with regards to the rig. Specifically, I would like to know what the I, J, P, & E are. Any other rig details that can be provided would be much appreciated. The boat in question has a Selden label on the mast and I’m not sure if they were around building spars in the 1980’s. So if the mast is not OEM, then I suppose it’s possible the rig dimensions were changed as well, although I doubt it. Any further info you can provide about the boat in general would be a valuable asset as well. Quote Link to post Share on other sites
raz88 96 Posted December 15, 2020 Share Posted December 15, 2020 Do you have a link to the boat? The lotus 950 was an evolution of the 9.2 and there are some that are a bit of a mix (9.2s with 30cm added to the hull which people call 9.5s etc), the 950 had a taller rig. Might help someone determine your measurements if you can confirm more info about the boat? Even if you can advise whether it's a single spreader masthead rig or the twin spreader version. Quote Link to post Share on other sites
raz88 96 Posted December 15, 2020 Share Posted December 15, 2020 This might help? http://bp3.blogger.com/_l1H8YgRf6Ec/RoVv5k0SjGI/AAAAAAAAABs/22R-l8jiejw/s1600-h/boat2.jpg Quote Link to post Share on other sites
Dan 0 Posted December 15, 2020 Author Share Posted December 15, 2020 14 hours ago, raz88 said: Do you have a link to the boat? The lotus 950 was an evolution of the 9.2 and there are some that are a bit of a mix (9.2s with 30cm added to the hull which people call 9.5s etc), the 950 had a taller rig. Might help someone determine your measurements if you can confirm more info about the boat? Even if you can advise whether it's a single spreader masthead rig or the twin spreader version. The only links I have are from Sailboatdata: https://sailboatdata.com/sailboat/lotus-95 and the link posted above. Definitely double spreader rig. The advert is here: https://www.popyachts.com/racing-sailboats-for-sale/lotus-95-31-in-san-pedro-california-228374 Very inexpensive, but no working engine and looks like the saildrive leg will need replacement at a minimum. The boat needs a whole lot of work. Most likely one of those free is too much deals. It only has a couple of sails apparently and I would guess they are well used or completely toast. I have some excellent sails from my previous boat, which If they can be made to work on this boat may make buying this boat make a bit more sense. This is the reason I am inquiring about the rig dimensions. Quote Link to post Share on other sites
Sudden5869 17 Posted December 15, 2020 Share Posted December 15, 2020 Go to http://phrf.yachtingnz.org.nz/export-options Download measurements and look for a Lotus 950.... there is one with current measurements. "Wright One" Was just on another Lotus 950 a week ago (Visual Progress). NZ built and original rig. It also runs a Selden Rig. Quote Link to post Share on other sites
Dan 0 Posted December 16, 2020 Author Share Posted December 16, 2020 3 hours ago, Sudden5869 said: Go to http://phrf.yachtingnz.org.nz/export-options Download measurements and look for a Lotus 950.... there is one with current measurements. "Wright One" Was just on another Lotus 950 a week ago (Visual Progress). NZ built and original rig. It also runs a Selden Rig. Thank you. That was exactly what I was looking for. Jib/spin hoist is a couple of feet more and mainsail hoist is a foot less than I was hoping for - so I don't think my existing sails are going to work on it. Quote Link to post Share on other sites
chariot 243 Posted December 16, 2020 Share Posted December 16, 2020 Good boats but seems like a lot of work. Quote Link to post Share on other sites
