Sealing Sheet Tracks
1 hour ago, Sail Rock said:
Same here. Get someone to hold the screw in place with a screwdriver to prevent it turning and breaking its bond with the sealant, while you tighten the nut from below.
You have had success with this method Sail Rock? Currently in the process of doing the first track at the moment using Sika 291. Cheers.
Yes, no leaks since I reinstalled the Genoa tracks several years ago. I do this for all deck fittings. Occasionally a fitting has failed to completely seal so just have to remove and repeat.
  • Upvote 1
