lateral 113 Posted January 18 Author Report Share Posted January 18 Which reminds me of the question whether its better to have a built in fail point that limits damage or make everything proportionally robust to load so the failure point will be unknown and can be catastrophic. Gooseneck damage after bs shackle failure. Wrap around tags/cleats are 2mm aluminium welded to 6mm Al bar that takes fitting. Mechanically fastened to track. Welds on each were small. Point of failure? I think my new hard vang exacerbated this. So do I beef it up so it wont break, or duplicate for stress relief? Quote Link to post Share on other sites
Steve Pope 111 Posted January 18 Report Share Posted January 18 That point is obviously the "weakest point" at this stage. given that it has lasted for a lot of years up to this point , I would be inclined to repair it in its current form, maybe an extra tack or two. By remaking it in a much stronger form could (will) shift the stress points. Quote Link to post Share on other sites
aardvarkash10 190 Posted January 18 Report Share Posted January 18 47 minutes ago, Steve Pope said: That point is obviously the "weakest point" at this stage. given that it has lasted for a lot of years up to this point , I would be inclined to repair it in its current form, concur. The key here is that the damage was controlled - the boom was still attached and you were not dealing with a collapse of the standing rigging. Replacing the track etc is relatively easy and cheap. A controlled deformation like this is much better than either a total failure or so much rigidity that the forces are transferred to the next point of failure. Quote Link to post Share on other sites
