bigal.nz 59 Posted January 24, 2021 Share Posted January 24, 2021 Hi, We have a MaxProp 3 bladed classic that we want to sent to the states for a overhaul. A bit of a long shot - but does anyone have a spare MaxProp we can use to keep us going while the other prop is sent to the states? I will check shaft dia and blade size today. Al Quote Link to post Share on other sites
Dtwo 157 Posted January 24, 2021 Share Posted January 24, 2021 You'll probably need taper details as well. Hopefully it will be a standard taper. Would MaxProp hold the details of that? Quote Link to post Share on other sites
waikiore 399 Posted January 27, 2021 Share Posted January 27, 2021 The only boats with a 'standard ' taper that I have come across in NZ are the European white boats with ISO tapers (1:10) Quote Link to post Share on other sites
Dtwo 157 Posted January 27, 2021 Share Posted January 27, 2021 Yes, there are many "standard" tapers. Humans! Quote Link to post Share on other sites
bigal.nz 59 Posted January 27, 2021 Author Share Posted January 27, 2021 30mm to 22.1. Quote Link to post Share on other sites
bigal.nz 59 Posted January 28, 2021 Author Share Posted January 28, 2021 30iso over 79mm. How do you find the kiwi prop. Definitely looking at it for a option. Quote Link to post Share on other sites
kiwi_jon 26 Posted January 28, 2021 Share Posted January 28, 2021 Don't you also to know the rotation direction? Quote Link to post Share on other sites
bigal.nz 59 Posted January 28, 2021 Author Share Posted January 28, 2021 RH, and it's a 18 inch prop. Sorry the info is slow. Quote Link to post Share on other sites
Island Time 1,235 Posted January 28, 2021 Share Posted January 28, 2021 I put my GB into reverse to stop that issue with the Kiwi Prop. Gives it a bit of resistance, and makes it feather again... Quote Link to post Share on other sites
bigal.nz 59 Posted January 29, 2021 Author Share Posted January 29, 2021 8mm key for MP. Quote Link to post Share on other sites
Fogg 427 Posted January 29, 2021 Share Posted January 29, 2021 18 hours ago, lateral said: Tried that once. The Kanzaki KM3P locked up and wouldn't go back to neutral. I was contemplating a solenoid lockup that unlocks when key is on, except I use key off/on to reset external regulator. I had that once but the engine still started quite happily with it in engaged in slow astern - whereupon it immediately released and returned to neutral as normal. Quote Link to post Share on other sites
