Stuffing box packing material
should be able to buy from marine shop. 6mm or 8mm from memory,when fitting should get 3 rings in and do not line splits up. plenty of grease.should drip when motoring but not when stationary.
  • Like 1
2 hours ago, aardvarkash10 said:
Dripping is becoming steady dribble.
Any recommended sources for packing material for repair of a traditional stuffing box?
Engineering suppliers generally carry it, certainly AES, maybe Paykels.
Otherwise any of the Beaumont St bandits (or wherever they are now)
  • Like 1
So what are you going to use?
Flax,Teflon, graphite, GTU, GFO, ultra X ?\
Only one I have experience with is ultra X which worked well and was predictable.
Pulling the prop shaft out this weekend to check wear. As had problems with drip rate recently. Adjusted out easily tho.
Anyone here had a negative experience with graphite?
Quote below from Rod Collins (MaineSail)
ABYC   the possibility of galvanic incompatibility with the shaft material.”I suspect what we are seeing in this photo is exactly the “galvanic incompatibility” the ABYC warns against.
"We now know where the ABYC stands on graphite packing but what about the largest prop shaft manufacturer in the United States, and possibly the world, Western Branch Metals?\
“Do not use graphite packing in the stuffing box. Instead, use a packing material that causes the least abrasion after the lubricant wears away. The use of graphite-impregnated packing is not recommended because of the possibility of galvanic corrosion of the shaft material.”
Now we have not only the ABYC but one of the largest prop shafting manufacturers on the planet both saying exactly the same thing. Do not use graphite packing’s. As they say your boat, your choice.
With all that said there are still many happy boaters who have had decent results with these graphite packing’s. Please remember however that they should not be treated as a set it and forget it packing. If using these graphite impregnated packing materials I would strongly suggest checking the shaft at least yearly."
  • Like 1
To clarify, that horrendous looking shaft was bronze btw.
If my prop shaft looks ok, then I'm back with graphite.
Or check what Gordon has to say.
I'm picking Stepping Out has an old-school system so it will likely be fibre.  There is a grease packing device fitted (very simple screw crown fitting) so I figure there is no real need ot go all high tech and fancy low friction.  The Reserve Bank of Fosters actually has quite reasonable pricing on fibre product by the metre so if no-one violently objects I'll probably go that way.
  • Like 1
  • Upvote 1
Where do you buy Ultra X in NZ?
Hey Harry - got any pictures of that?  I thought it might be a good way to go, especially if I can fit it semi-permanently ie not via a grease nipple
No sorry,from gun to gland we used a hose,gland had a self greaser on it 10mm?? so adapted gun to fit.
  • Upvote 1
Have you tensioned the stuffing box a little?   Do you have pictures of your one?
  • Like 1
My prop shaft is ok and is going back in with graphite ultra x.Very mild necking at gland. Suspect graphite is harder on ss shaft though.
Moral was/is ONLY hand tighten packing boss incrementally to get desired drip rate and save tools for locknut.
No on both counts.  My experience with this yacht so far is that if I adjust something it breaks or it is already at the end of its adjustment.
In light of that, I'm inclined to redo the packing so at least I know what I have - and its not expensive.
