MrWolf 0 Posted August 11, 2010 Share Posted August 11, 2010 In most places the foam goes in , in quite wide strips up to 1200 mm wide. So actually its still just vertical stripped but the strips are 1200 wide (and presumably a little less at bow/stern if needed to achieve a tighter curvature). Eamon - sounds like your putting in 'whole' sheets - ie. 2400 lengthwise? If so I'm thinking wastage is a little worse with Eamon's - though you could use it up in bunks, furniture etc. It looks as though putting in the foam at 600mm wide strips is going to work out the best. Wider strips do go in but it bows in the middle of the sheet. Quote Link to post Share on other sites
Guest Posted August 12, 2010 Share Posted August 12, 2010 I forgot the airex foam is about 1050x2180 so it was actually only 1050mm wide sheets laid end to end of the float. 1050mm was too short to curve around the F32 float, and my heater sheets are only 1200mm anyway. There is no issue with wastage for an entire build, plenty of places to use up the small pieces. I doubt I will be throwing out anything other than the smallest of offcuts. Photos attached if they are of any use?? I think I used 8 full sheets for each float side. Quote Link to post Share on other sites
Guest Posted August 12, 2010 Share Posted August 12, 2010 Sorry guys, I'm gonna keep putting up photo's. I don't really like Gary to get too many distractions and there are details I would like to keep confidential just at this stage. I have just managed to pick myself off the floor. Confidential details are you taking the pi$$. Whos gunna steal your secrets? come on tim!! Quote Link to post Share on other sites
samin 0 Posted August 12, 2010 Share Posted August 12, 2010 I forgot the airex foam is about 1050x2180 so it was actually only 1050mm wide sheets laid end to end of the float. 1050mm was too short to curve around the F32 float, and my heater sheets are only 1200mm anyway. There is no issue with wastage for an entire build, plenty of places to use up the small pieces. I doubt I will be throwing out anything other than the smallest of offcuts.Photos attached if they are of any use?? I think I used 8 full sheets for each float side. Hows progress? Send it I think the two 9m tris are having a bit of a comp to see who can build the coolest floats, bit unfortunate they couldn't pool there resources, typical kiwis Quote Link to post Share on other sites
Guest Posted August 12, 2010 Share Posted August 12, 2010 Just saw an email wioth the latest photos, I'll post them in the am (my wife wants me to go to bed) Quote Link to post Share on other sites
MrWolf 0 Posted August 12, 2010 Share Posted August 12, 2010 You are right Sam, it is a shame. Dan is welcome to use our mould if he wants (so is anyone else for that matter). But getting on with the job was the name of the game so we can get it sailing again. I'm hoping Dan will use our Centrecase, Foils and bearings on his new amas. But really if all you 8.5 guys were truly sensible, you would all be building a Dirty Deeds, because then you would all have the equal fastest boats and your class would get some tight racing. But we all know what Kiwi's are like, eh Sam ? Quote Link to post Share on other sites
Guest Posted August 12, 2010 Share Posted August 12, 2010 Good Morning Quote Link to post Share on other sites
Guest Posted August 13, 2010 Share Posted August 13, 2010 She looks good Tim good to see your well on your way. Quote Link to post Share on other sites
Guest Posted August 13, 2010 Share Posted August 13, 2010 How are yours comming on Dan. It is a bit of a trimaran grave yard at okahu bay at the moment. Quote Link to post Share on other sites
Guest Posted August 13, 2010 Share Posted August 13, 2010 Dont you worry she will be on the water soon enough and with some luck be a click quicker and safer. May even be able to keep up the ping tie in the conditions. No its all a bit slow but we have drawings and are ready to start the floats. Quote Link to post Share on other sites
Guest Posted August 16, 2010 Share Posted August 16, 2010 Here's the latest Quote Link to post Share on other sites
Guest Posted August 16, 2010 Share Posted August 16, 2010 .....just how long are these floats mr wolf ? are you leaving the 9m class ?? if your foam is 600mm wide on average I work out that you floats are rather long ? or are these details "confidential"..... ? Quote Link to post Share on other sites
MrWolf 0 Posted August 16, 2010 Share Posted August 16, 2010 A 9m class, that's a great idea. Lets have a height restriction on the rig We aren't 9m anyway, we are 9.2m, and despite appearances our LWL is still going to be 9.2m. But you guys are all such great detectives Anyway had a HUGE hands up with the bulkheads, they are all ruined in the autoclave, and are unusable and unsavable. Quote Link to post Share on other sites
Guest Posted August 17, 2010 Share Posted August 17, 2010 Latest Quote Link to post Share on other sites
SloopJohnB 323 Posted August 17, 2010 Share Posted August 17, 2010 Latest Squid whats the first photo? Did you get mixed up, as it looks I you are trying to bring contraband in to the country. Quote Link to post Share on other sites
MrWolf 0 Posted August 17, 2010 Share Posted August 17, 2010 Latest Squid whats the first photo? Did you get mixed up, as it looks I you are trying to bring contraband in to the country. $4k worth of Carbon and Nomex that was laid up as the Bulkheads but got wrecked in the autoclave Quote Link to post Share on other sites
ScottiE 174 Posted August 17, 2010 Share Posted August 17, 2010 s**t Wolfie what happened? Looks pretty bloody aweful. Too hot , too cold, too much pressure, not enough, some one added yeast to the resin?!? Quote Link to post Share on other sites
Guest Posted August 18, 2010 Share Posted August 18, 2010 in a past thread there was a comp for worst song lyrics. we should start another for this. my nomination is a song by ralph harris. tie me kangaroo down sport! he didn't secure th job down well and it blew of the table and cured on the pi$$ Quote Link to post Share on other sites
MrWolf 0 Posted August 18, 2010 Share Posted August 18, 2010 Well we fitted a new fan to the autoclave that creates more wind. The whole vacuum bag is around 13m long and only weighed about 25kg. Even though the bag was glued down all over to the bed, and taped every 600mm, the wind got under the bag and flogged it round like a rag doll. The bulkheads must have still been "wet" when that happened because they cured in nice little circly shaped things. Quote Link to post Share on other sites
SloopJohnB 323 Posted August 18, 2010 Share Posted August 18, 2010 Can you have wind/air flow in a negative pressure? Quote Link to post Share on other sites
