SthnJeff 18 Posted February 27, 2014 Author Share Posted February 27, 2014 Awesome info and tips! it has narrowed down the search hugely. I had also heard Lancers really good, but at around $3500k it is around 25% of the value of the Raven! I will keep a good eye out on TM. I was originally looking at tying the inflatable to the stern boarding platform but the bamboo "davits" idea has me intrigued and will look into it. That little plywood twin hull looks interesting BP, unfortunately I don't really have the time or space to start something like that! Quote Link to post Share on other sites
Guest Posted February 27, 2014 Share Posted February 27, 2014 The rollup vs RIB decision also depends on payload and regular distance travelled. If it is just you, a couple or 2 adult couples and primarily visiting another boat or beach at an anchorage a rollup is ok. If a family and on a mooring or the piles, a RIB is far better. The Raven has the large foredeck so a RIB can fit on there for passage. Otherwise towing around the Gulf is fine in most conditions. Quote Link to post Share on other sites
Atom Ant 0 Posted February 28, 2014 Share Posted February 28, 2014 I had a southern pacific roll up for around 15 years. I used to roll it up and store it away over winter for the first 5 but after that it lived outside. I did make my own ply floor for it which made it a lot easier to get in and out of. Rowed fine for short distances, and motored well with my 2 hp DT2. Excellent boats and they last well. Quote Link to post Share on other sites
Terry B 70 Posted July 23, 2020 Share Posted July 23, 2020 Hi all, back on page 1 of this thread, 'Cloughy' and 'AB1974' mention a system for attaching temporary davits for putting the inflatable on - however the picture Cloughy attached isn't there. Anyone got a pic or diagram I can have a gander at please?? Ta in advance. Quote Link to post Share on other sites
Fogg 427 Posted July 23, 2020 Share Posted July 23, 2020 https://truekit.nz/ NZ made but using Valmex (German material) which looks heaps better than PVC. Might not quite fit OP's budget and size but for others worth a look.. Quote Link to post Share on other sites
Gappy 9 Posted July 23, 2020 Share Posted July 23, 2020 4 hours ago, Aleana said: https://truekit.nz/ NZ made but using Valmex (German material) which looks heaps better than PVC. Might not quite fit OP's budget and size but for others worth a look.. Valmax is PVC its made by a German company called Mehler Technologies it used to the industry standard but there is other brands that have really good products also now. There is now a material called TPU which you can weld like PVC but it has properties closer to Hyaplon but at half the cost. Quote Link to post Share on other sites
Terry B 70 Posted July 23, 2020 Share Posted July 23, 2020 Okay, clearly I did not explain myself well? I'm talking about the apparatus that holds the inflatable on the stern - not what/which dinghy to buy/own. I thought I had made it clear - davits? Cloughy & AB1974 comments in first part of thread? Quote Link to post Share on other sites
Gappy 9 Posted July 23, 2020 Share Posted July 23, 2020 Davits are called weaver davits glue the pads on then select your transom attachment style. Southern Pacific have them Quote Link to post Share on other sites
Terry B 70 Posted July 23, 2020 Share Posted July 23, 2020 Okay, I'm beginning to regret restarting this thread. Cannot see anything on Sth Pacific that is remotely what cloughy or AB were talking about. Quote Link to post Share on other sites
eruptn 89 Posted July 23, 2020 Share Posted July 23, 2020 If going for the 'soft floor', the big improvement is having a inflatable keel. Makes a big difference to the rowing abilities. Quote Link to post Share on other sites
Terry B 70 Posted July 23, 2020 Share Posted July 23, 2020 I give up. do none of you go back and read what cloughy and ab said Quote Link to post Share on other sites
Terry B 70 Posted July 23, 2020 Share Posted July 23, 2020 Whoops, I thought I'd deleted/retracted/altered my last post but I didn't - clearly. No offence meant to anyone. I'm talking about the STRUCTURE on the stern the AB and Cloughy mentioned, - bamboo - or other - please read what they said before posting a reply to my post. 1 Quote Link to post Share on other sites
Gappy 9 Posted July 23, 2020 Share Posted July 23, 2020 All hes taking about is sticking two bars out the back of the boat lashed to the stainless pushpit that the boat is then hung off i.e alloy tubes or large bamboo poles. Then some blocks hung off these to pull the boat in and out of the water A cheap arses version of what Sabre has posted above 1 Quote Link to post Share on other sites
Terry B 70 Posted July 23, 2020 Share Posted July 23, 2020 Rightio, thanks Gappy & Sabre................ Quote Link to post Share on other sites
rossd 16 Posted October 17, 2020 Share Posted October 17, 2020 On 27/02/2014 at 6:30 PM, Pumbaa said: If you can find a hypalon dinghy in reasonable condition, Pumbaa you sound like a person that might point me in the right direction. I have a Avon hypalon but need an Outboard mount. I am up to the Mark 3 plywood model now but believe a factory glass one was made. Any ideas where to find one? Quote Link to post Share on other sites
