Folding Lewmar Wheel / Pedestal / Silva Compass
the muse
TradeMe 725413222
6 Spoke Folding Lewmar Wheel, Lewmar pedestal, Silva Compass.
Lewmar Cobra System. Beautifully engineered Lewmar (Stainless Steel) folding wheel, pedestal, and rack & pinion mechanics - designed for sensitive steering in aft cockpit yachts up to 45ft. Silva Compass.
The principle of the Cobra steering system is based on the precision gearcut circular rack and pinion in the head of the pedestal, providing the necessary mechanical advantage. The quadrant gear is connected to a stainless steel downtube, at the base of which is an output lever. This connects to a similar lever, mounted on the rudder stock, via a fully adjustable draglink.
All shaft work is carried through high efficiency sealed ball races and the mesh of gears is controlled via shims under the input, eliminating any lost motion. The input socket also houses a powerful and progressive friction brake for dampening the wheel, when at anchor, for example.
http://www.lewmar.com/products.asp?id=8870&lid=27621
Silva Compass includes electrics for light. Adjustment screws for compass calibration easily accessible. Covers included.
Pedestal height: 994mm
Pedestal base width: 250mm
Wheel diameter: 1007mm
Wheel width (folded): 630mm
021 384654
Very good all round condition. Probably about 5 years old. Just removed from boat as no longer required. All units have been carefully removed with all static and moving parts intact.
