Brass underwater
Looking at screwing some brass rubbing strips underneath the stub keels on a cat. It will be screws through glass into timber so I will drill oversize holes filled with epoxy glass mix and then screws into that to keep the timber sealed. Will stainless screws work or should I use brass to minimise corrosion of dissimilar metals.
