vic008 17 Posted June 20, 2014 Share Posted June 20, 2014 and found corrosion bad under the 2 winches. A good wire brush I think and need something to kill the corrosion, then a patch over? Link to post Share on other sites
Guest Posted June 20, 2014 Share Posted June 20, 2014 How bad is 'bad'? If it's real bad you may need to patch it up i.e. weld something in there maybe??? I stripped mine, wizzed a wire brush gizmo over the odd bit of icky then etch primed it. It was painted and will be repainted. Luckily when Matrix (I think) painted it they did a magnificent job so there was bugger all nasty. I am assuming you have alloy Vic. Link to post Share on other sites
