Creating access to oil filler via cockpit floor
Quick question; is there any reason one can not install the flush mount deck fitting for a water tank or fuel tank above the oil filler on ones motor. It should be water proof.
My oil filler has about 80 mm, space above it, but is back about 0.8m from the front, or 0.5m from the side access. Not easy for getting the new oil in.
The idea is remove bung and insert funnel an pour in oil ?
