erice 732 Posted December 16, 2016 Share Posted December 16, 2016 from a fish farm? http://www.nzherald.co.nz/nz/news/article.cfm?c_id=1&objectid=11768592 Quote Link to post Share on other sites
Fish 0 Posted December 16, 2016 Share Posted December 16, 2016 It's water main pipe. Polyethylene. It will be PE 100, but I can't quiet pick the size from the photo. Probably 250 outside diameter. The end looks a lot like a towing head for underground directional drilling. That is how most water main is installed. For water main though, the towing head is only installed on one end. If it has a head like that on both ends, then someone has jimmied this pipe up to be some sort of floating boom, or other non pipeline use. I note the towing eye is stainless. Civil contractors would never bother with that, indicating it is designed for marine use. Which would also explain why it's in the marine environment. So not sure what it was being used for, but that is 100 % standard watermain pipe. Quote Link to post Share on other sites
erice 732 Posted December 20, 2016 Author Share Posted December 20, 2016 The 100m long black pipe is the property of salmon farming company Huon Aquaculture, which is based in Tasmania, Australia. After losing the pipe, the company immediately launched a search involving a number of vessels and aircraft but it was not found. Since losing the pipe Huon Aquaculture have moved to orange pipes to make them more visible and they also fit them with GPS tracking devices. Huon Aquaculture is investigating options for retrieving the pipe. http://www.nzherald.co.nz/nz/news/article.cfm?c_id=1&objectid=11770824 shows how expensive they are but hit 1 of those, square on, in the middle 50m, with a blunt bowed vendee boat travelling at 17 knots what could happen? maybe they should go back to swept bows? Quote Link to post Share on other sites
