Refrigeration
i can help you out, a special price for crew.org members
$250 inc, full service of system includes, change dryer, pressure test system-leak test repair any small leaks, if hoses need to be replaced it is a extra cost, charge an set super heat on unit
2 month warranty
super heat is the difference between the back pressure pipe temp and the refrigerant temp, this needs two be around 3-6 k other wise the system will flood back an take the oil out of the compressor with it, as oil is attracted to super cold refrigerant, we all know what happens when a compressor runs with out oil :wtf:
