Sailing Taranto 2 Posted April 18, 2024 Share Posted April 18, 2024 Asking again if anyone has experience re-bushing the pintles and gudgeons on a Lotus 9.2. Does the skeg and rudder come out as one piece? Or can just the rudder be removed to fix. How is it attached? Does anyone have diagrams or plans for these boats? Many thanks in advance. I'm on the hard, trying to get the job done as quickly and economically as possible. Cheers Rick Quote Link to post
alibaba 88 Posted May 25, 2024 Share Posted May 25, 2024 I don't know if they are all built the same, but on my Lotus 9.2 there are three pintles and gudgeons connecting the skeg to the rudder blade. To remove the rudder blade and get at the bearings, you actually remove the each piece of wood on the rudder blade just above the supports. It's about 50mm high, and is usually screwed or glued in there as a separate piece. Once you have removed them, the rudder can be lifted off the pintles. Quote Link to post
