Guest Posted August 18, 2011 Share Posted August 18, 2011 I have the TP10 which works really well but often disengages downhill in any more than a 2m swell. However - I'm not really being fair on the unit as it really is a bit underpowered for the yacht......my mistake in the first place. Still worth it though - makes a huge difference. Link to post Share on other sites
ab1974 1 Posted November 22, 2011 Author Share Posted November 22, 2011 Right, about to purchase a Simrad TP. Having read the instruction manual it says: The Tillerpilot houses an internal fluxgate compass and should therefore be mounted away from sources of magnetic interference, such as the vessel’s steering compass or external loudspeakers. The minimum safe distance is 1m (3 ft 3 in). to place the TP atleast one meter away from items that may interfear My cockpit speakers which are already fitted will be within 1m (probably closer to 500mm actually) from the unit. Anyone else fitted a TP close to their speakers and did it have much impact on performance?? Link to post Share on other sites
Absolution 7 Posted November 22, 2011 Share Posted November 22, 2011 My speakers are within 1m of the tillerpilot (also Simrad) and it works fine. It may struggle to do its initial calibration but it doesn't seem to effect operation. Link to post Share on other sites
ab1974 1 Posted November 23, 2011 Author Share Posted November 23, 2011 Cheers Hamish Link to post Share on other sites
urwl58 0 Posted November 29, 2011 Share Posted November 29, 2011 Here are a couple from Craigslist. I've noticed tilerpilots tend to go quickly, so you may have to repeat the search every few days if these have already been bought. (I Googled "craiglist tiller pilot" and "craigslist tillerpilot") BTW, I got mine free from a friend who got it with a boat he bought and later sold. He didn't even know what it was. It wasn't functional by the time I got it, but I opened it up, and in about two minutes unfroze the little electric motor inside, and now it works perfectly. So there's hope for the "non-functioning" ones. Link to post Share on other sites
Guest Posted November 29, 2011 Share Posted November 29, 2011 Has Craigslist made it to NZ??? Link to post Share on other sites
Guest Posted November 29, 2011 Share Posted November 29, 2011 Looking to buy a tiller pilot for my Elliot 7.9. Any thoughts / feedback on the Simrad / Raymarine or others? Main be used when shorthanded when doing sail changes or motoring. Do I need one or am I better off with a simple rope / shock cord system? Try a girlfriend, wife, sailing mate. Cooks, smiles, keeps you busy & warm on cold wet nights. Gawd you's guy's is thick, sometimes. james Link to post Share on other sites
tuffyluffy 76 Posted November 29, 2011 Share Posted November 29, 2011 Looking to buy a tiller pilot for my Elliot 7.9. Any thoughts / feedback on the Simrad / Raymarine or others? Main be used when shorthanded when doing sail changes or motoring. Do I need one or am I better off with a simple rope / shock cord system? Try a girlfriend, wife, sailing mate. Cooks, smiles, keeps you busy & warm on cold wet nights. Gawd you's guy's is thick, sometimes. james Thats the best, most legible thing you've said on this forum, ever. Link to post Share on other sites
Guest Posted November 29, 2011 Share Posted November 29, 2011 Oh yeh Tuffy, for about 2 weeks and then back to doin it yourself! Link to post Share on other sites
Guest Posted November 29, 2011 Share Posted November 29, 2011 Has Craigslist made it to NZ??? No point - Who would take on Trademe in a market of 4m people? Ebay came and went in a matter of months. Link to post Share on other sites
Guest Posted November 29, 2011 Share Posted November 29, 2011 My Tp32 is making noises now and I wonder at the cost to repair. Its a bit small for my Racing Supertanker34 but I believe its the biggest available. I hooked mine to the garmin handheld gps via nmea which made it more reliable. Using the satelite as a compass now so no worries with the fluxgate picking up interference. I can also set a goto waypoint which I do by setting the sails and course then put a waypoint at the end of the pointer on the chart. Its ok as long as the winds not veering too much. Link to post Share on other sites
Guest Posted November 29, 2011 Share Posted November 29, 2011 Would be great if we had a locally made, affordable windvane that is easy to set. Maybe just a pendulum rudder controlled by tillerpilot. That is the power comes from the pendulum and the control from the tiller pilot. The pilot would not have to use much force to turn the pendulum rudder which would make it last longer. Link to post Share on other sites
