Guest Posted August 21, 2012 Share Posted August 21, 2012 I am replacing rudder bearings and also need to replace the lip seal at the top of the rudder tube. Who are the suppliers for marine seals? Link to post Share on other sites
chic014 0 Posted August 21, 2012 Share Posted August 21, 2012 Not sure if there is a specialist marine seal place but seal imports have always been pretty good in my work. They seem to have a really good range. http://www.sealimports.co.nz/ Catalogue here: http://www.sealimports.co.nz/SIL%20Catalogue%20NZ.pdf Link to post Share on other sites
Guest Posted August 21, 2012 Share Posted August 21, 2012 Thanks for that . Their catalogue looks pretty comprehensive . I will give them a call Link to post Share on other sites
Guest Posted August 22, 2012 Share Posted August 22, 2012 If using a conventional lip seal against sea water then you need a stainless bootspring. If this isn't available in the size you're looking for then a rubber "O" ring of a size to put moderate tension on the lip should be good for a rudder shaft. Link to post Share on other sites
