NZL3551 0 Posted October 27, 2012 Share Posted October 27, 2012 Magma Kettle 205 Gas BBQ For Sale. Uses propane gas bottle. Only used once and comes with rail mount. New they are prices at $280.00. Yours for $180.00 This grill was designed for economy without sacrificing functionality. Made of 100% 18-9 mirror polished stainless steel, it will give you the safety, durability and performance required of a marine grill. It uses highly efficient radiant plate heat distribution system in conjunction with convection heating technology to achieve hot, even temperatures while using a minimum of fuel. It comes to temperature very quickly and is great for searing steaks or just grilling up some burgers and sausages. The patented swivelling turbo venturi tube allows you to adjust the control valve inboard, outboard, left or right wherever it is most convenient to you. This design also allows for quick safe fuel canister changes even while grilling. The turbo venturi tube in combination with the newly designed burner virtually eliminates blow-outs. The grill quickly disassembles without tools for easy clean-up. Detailed information here https://www.whitworths.com.au/main_item ... lutePage=1 Link to post Share on other sites
Adi0524 0 Posted November 7, 2012 Share Posted November 7, 2012 NZL3551 Thanks for share wonderful link!!! Link to post Share on other sites
