Guest Posted January 30, 2013 Share Posted January 30, 2013 I have a couple of old thru-hulls doing nothing - transducer, speed/knot meter. What is a common approach to this? pull the old fittings out and glass up the holes? or leave them in and hope they never leak!? In the future I could use the paddle-wheel or at least its hole if I get concerned about seeing my speed over water, but have mounted a shoot through style transducer now that seems to be working ok (I'm still amazed it works at all!) so won't need that hole again. Link to post Share on other sites
Changed 10 Posted January 31, 2013 Share Posted January 31, 2013 Glass it up next time you're out. Best long term solution. The fewer holes in the hull the better. Link to post Share on other sites
