lotus92owner 0 Posted March 28, 2013 Share Posted March 28, 2013 we are repowering a lotus 9.2 and considering the gearbox ratio - 2:1 or 2.6:1. Does anyone know if a shaft drive on a lotus 9.2 can take a 16" dia prop with enough clearance between blade tip and hull? If not may need to take a dip with tape measure as she is in the water. Link to post Share on other sites
Guest Posted March 28, 2013 Share Posted March 28, 2013 I had a 16 inch prop on the marauder for a bit. Fit fine on the shaft but depends on your strut. Should be fine though Link to post Share on other sites
wheels 543 Posted March 28, 2013 Share Posted March 28, 2013 You will have to check it with the tape mate. Unless you can find one up on the hard around the yards. Just because a 16 might fit on a Marauder is no sure answer for a 9.2 Link to post Share on other sites
alibaba 80 Posted March 31, 2013 Share Posted March 31, 2013 t the answer to your question is yes. I have a Lotus 9.2, Yanmar 2GM 20F, running a 16x9 prop. 5 and a half knots at 2000 revs. seems fine to me. Link to post Share on other sites
