Electrical WOF
morspeed
you Need the main switch, and being double pole this will eliminate any stray currents form other boats so keep that :thumbup: and a RCD down stream of that, the Hot water cylinder should not be covered by the RCD as you will get nuisance tripping due to earth leakage. I would go for the same size element down sizing will just take twice as long to reach temp and end up using just as much power.
Hope this Helps - I'm sure you Electrician will sort you out
