Guest Posted May 20, 2013 Share Posted May 20, 2013 Hello all, I am rebuilding a Sonata 8 keelboat. I am putting a inboard rudder under it and have an old Quarter tonner rudder that might fit. Question is ,is the shaft big enough, its about 50mm with a 3mm wall thickness. What do you think? Peter Link to post Share on other sites
w44vi 17 Posted May 20, 2013 Share Posted May 20, 2013 YNZ has a chart of min shaft size vs blade area Look at page 30 http://www.yachtingnz.org.nz/sites/yach ... 0FINAL.pdf Link to post Share on other sites
Guest Posted May 20, 2013 Share Posted May 20, 2013 Does the YNZ chart apply to hollow shafts or solid. Boat is of the quarter ton type, what is used in them? Peter Link to post Share on other sites
