Guest Posted August 21, 2013 Share Posted August 21, 2013 Have finally got the home situation as it should be, 2 cars parked on the street, and a kayak, Opti, and a newly acquired Sunburst in the garage. Not quite the full fleet, yet, but a work in progress. GRP Sunburst needs some repairs, bonding between the hull and deck molds coming apart on the cockpit floor up forward, doesn't look too hard to grind out the tabbing and reglass. I've some CRC / Ados epoxy which has been kept under the house since the keelboat days (5 years ago?), courtesy of Richmond winter series I think. I've been using odd bits for fixing stuff around the house and with filler, and it still seems to cure pretty hard, in a normal time frame. Its discoloured a bit, the hardener is pretty brown, but otherwise seems ok. Am I ok to keep on using it for laminating? Other than it seeming to cure well with glue powder or filler powder, is there any way of checking before slapping it into a sunburst? Link to post Share on other sites
Guest Posted August 22, 2013 Share Posted August 22, 2013 Is it worth any risk at all? Get some new stuff and then you know its ok and maybe use this old stuff for cosmetics. Link to post Share on other sites
wheels 543 Posted August 25, 2013 Share Posted August 25, 2013 It's fine. Just watch your nose around the hardener as it can be a bit wiffy with Amonia. If you notice a crystal build up in the liquid, warm it for awhile and it all should turn back to liquid. Link to post Share on other sites
idlerboat 116 Posted August 25, 2013 Share Posted August 25, 2013 ....what wheels said, sorry not allowed to say who, but, expect to have a slower reaction (temp) and set time. Strength still the same. Link to post Share on other sites
Guest Posted August 25, 2013 Share Posted August 25, 2013 Thanks folks. I suspected as much, the manufacturer's are hardly likely to promote a 5 year shelf life, not much point asking them! Hardener is certainly a little wiffy, but not working in enclosed space, and will allow some extra time before loading up the mighty sunburst! Cheers Link to post Share on other sites
