Yourmomm 2 Posted December 16, 2018 Author Report Share Posted December 16, 2018 How much for the Dodger, chariot? chariot 1 Quote Link to post Share on other sites
Yourmomm 2 Posted December 16, 2018 Author Report Share Posted December 16, 2018 (edited) The only reference I have is NZD 800, but that was more than 10 years ago in Lagos, Portugal; a dodger replacement onto.pre existing frame, for a narrow beamed 32ft long keel ketch. And I thought that was a bit much, at the time... Edited December 16, 2018 by Yourmomm Quote Link to post Share on other sites
lateral 111 Posted December 16, 2018 Report Share Posted December 16, 2018 Thats really cheap. I know of several people charged over $800 just to change a dodger window. 3K or more is not uncommon. Not unhappy, only one I've purchased, so nothing to go on. Works a treat. Seems a lot for a couple of ss hoops,some canvas & clear plastic but then anything custom is time consuming. and then theres boat bucks and miserable old gits like me. Hell, anybody wants me to build something for nothing then theres got to be some other bloody good reason not to tell them to FO & bother somebody else. Quote Link to post Share on other sites
Yourmomm 2 Posted December 16, 2018 Author Report Share Posted December 16, 2018 At these prices, I'm liking crazyhorse's suggestion more and more... Quote Link to post Share on other sites
nagy592 21 Posted December 16, 2018 Report Share Posted December 16, 2018 I went on this path about a year ago and I ended up with an acceptable hard dodger (just search for it here), and I don't regret. Ever since I sold the boat and the current one has a dodger with a bit of life left so I will do the same thing next year or the year after. I also made my own "stack-pack" with lots of support from here. However, I've been "pushed" to do it as not many people in Canterbury who does nice canvas work for boats on a reasonable price. Also I'm in a comfortable position to be able to invest a decent amount of time to projects as well. If you up to, let's get in to it. If you are in the hurry and have some money to throw on , don't think about DIY. All up to you. If you go for make it out of fabric,Sailrite has a bunch of great tutorial on Youtube, that was very helpful to set the mind for it, but you also have to improvise and put your creativity in. All material available locally so you don't have to pay premium price to get it here from the states. Whatever you decide, good luck for it and show us the result if you don't mind. Quote Link to post Share on other sites
lateral 111 Posted December 16, 2018 Report Share Posted December 16, 2018 Yep, you got the time, some skills, have at it. Very satisfying. Quote Link to post Share on other sites
chariot 133 Posted December 16, 2018 Report Share Posted December 16, 2018 How much for the Dodger, chariot? Don't have a breakdown of items. As in my earlier post it was about $1600 for the whole lot Quote Link to post Share on other sites
chariot 133 Posted December 16, 2018 Report Share Posted December 16, 2018 Forgot to mention the price also included a tiller cover and 3 sheet bags. Quote Link to post Share on other sites
Crazyhorse 47 Posted December 17, 2018 Report Share Posted December 17, 2018 It's not hard to do: Get canvas repaired then stretch very tight over the frames on the boat. Cut out the silly plastic window. Mix up a good dollop of polyester resin and start brushing it on making sure you get it into the fabric. Concentrate on the seams and stitching plus around where the new window will go. You will need to do both inside the dodger and out. Once cured give it a good wash with sugar soap and when dry do the outside again this time laying glass strip where the seams are inside and out. When cured wash outside, dry then it's time to start lying the mat. Can't remember what weight glass we used as did this a long time ago and Halfmoon Bay. Avoid voids and air bubbles and go for over all consistency by running 2 cross laminations. Once cured, you can now lift the dodger off, careful it will still be flimsy and could crack under stress. Lay it roof down and give it a good clean. Once dry treat it with alcohol (not meths!) rubbing off the waxy finish. Now time to strengthen it with epoxy. Put epoxy around the window surround and inside the voids where the steel frames go and coat the entire inside with epoxy. Let cure then refit to your vessel. Now do the same outside. You will need someone to keep the epoxy mixes coming as it needs to be done all in one go. Don't mix too much of it will catch fire. Once done, clean again, no need for the alcohol then put the gelcoat on. Done! Quote Link to post Share on other sites
Vorpal Blade 87 Posted December 17, 2018 Report Share Posted December 17, 2018 By all means have a go yourself, the Sailrite kits and their vids etc can make it look easy. Their "instructional" videos are done with guys that have been doing it for years and tend to make quite difficult/fiddly things look heaps easier than they actually are, particularly if you want it to look good at the end of the job. Machinery is important, it's not a job for mums home sewing machine, you need a walking foot machine that can deal with large thread sizes. And eyelets etc etc If you have not done it before I reckon the hours in a hard top option are similar to what you would put in if you were learning how to make a nice looking fabric dodger first time up. If you are going to go down the solid panel path do this.... Get 5mm H80 foam sheets cut to shape to basically match the panels on the frame, hot glue gun them onto the outside of the frame and where they meet the deck, make them fit snugly together. Note - do not cut out the window at this stage Once all in place bog up the gaps with epoxy and skin the whole lot on the outside in one go with a 450GSM double bias/epoxy sticky stuff. The whole lot will release quite easily but a knife/screwdriver can assist on the grabby bits. Turn it over and fair clean/skin the inside - (at this stage you have the chance of burying wires in the foam before skinning so you can have internal lights etc with hidden cable. ) Mark what shape window you want and then take the while thing to a plastic window guy and they will mold a window to perfectly fit. Cut window hole, paint, attach window and Viola you have a hard to just like your dodger you can attach to the boat using 3M 5200. Or it would be between $10-1300 ish to pay someone locally to have it made made in a Sunbrella. Im off sailing - back January subject to weather. Sabre and Fish 2 Quote Link to post Share on other sites
