Guest Posted August 11, 2010 Share Posted August 11, 2010 I am looking for recommendations for someone who has and / or can instal a Garmin GPS and Fishfinder I have recently purchased. If anyone has experience or knows someone who has I would be grateful for recommendations. I am Auckland based at Westhaven. Link to post Share on other sites
wheels 543 Posted August 11, 2010 Share Posted August 11, 2010 I would have thought there would have been someone at Westhaven that could help you Grazer. Any Marine Sparky there? Do you need the transducer mounted through hull?? The sparky should be able to either do that or tee someone up to be able to do it. But the boat would need to be lifted out. A lift and hold should be long enough to get a transducer through. If I was up there i could help you. But I ain't..so I can't. Link to post Share on other sites
Atom Ant 0 Posted August 12, 2010 Share Posted August 12, 2010 Hi again Grazer. I know of one crowd called Electronics Afloat. They're close to Westhaven. What I don't know is what they're like. I had work done by them on my previous boat but that was 12 years ago so i doubt there's any relevance to today. A quick squizz at the Marine Industry Association website throws this up. https://secure.zeald.com/nzmarine/resul ... =electrics Good luck! Link to post Share on other sites
rigger 47 Posted August 12, 2010 Share Posted August 12, 2010 Hi again Grazer. I know of one crowd called Electronics Afloat. They're close to Westhaven. What I don't know is what they're like. I had work done by them on my previous boat but that was 12 years ago so i doubt there's any relevance to today. A quick squizz at the Marine Industry Association website throws this up. https://secure.zeald.com/nzmarine/resul ... =electrics Good luck! EAL, good people Link to post Share on other sites
Jon 360 Posted August 12, 2010 Share Posted August 12, 2010 Or do it your self Not hard, the red wire goes to a switchy thing on the back of the switch board and the black wire to the buzz bar with all the other black wires Then the transducer just saw a 50mm hole next time your out bobs your uncle fannys your granny I did mine, it only gets a bit tricky if your hull is a soft core. The instructions in the box are pretty good. And I'm only a dumb dairy cocky. Link to post Share on other sites
