Kick Ass 47 Posted September 24, 2018 Author Share Posted September 24, 2018 Have already removed form the boat to pressure test. If my spare 1 is no good i was wondering what options are out there that are economical? Quote Link to post Share on other sites
Island Time 1,235 Posted September 24, 2018 Share Posted September 24, 2018 Depends what the problem is. Albany radiators have repaired some for me... Quote Link to post Share on other sites
Toltec 7 Posted September 24, 2018 Share Posted September 24, 2018 What you have to check now is that salt water has ot entered the system if it has its you are looking at replacement did a 10.50 fridge a few years ago but the fault was picked up quickly and we managed to flush the system. If it has been sitting for a while I would say the system is contaminated.I think you might be spending good money on bad.New 12volt system and a good solar panel will be a lot cheaper or a 10litre bock of frozen water in the freezer would give you 3 to 5 days. I must be the only Refrigeration engineer who doesn’t have a fridge on his boat pulled ours out as could see to many problems with it as it was old.Fixing what you have would be lucky under $4000.00 even at mates rates Quote Link to post Share on other sites
Kick Ass 47 Posted September 24, 2018 Author Share Posted September 24, 2018 What you have to check now is that salt water has ot entered the system if it has its you are looking at replacement did a 10.50 fridge a few years ago but the fault was picked up quickly and we managed to flush the system. If it has been sitting for a while I would say the system is contaminated.I think you might be spending good money on bad.New 12volt system and a good solar panel will be a lot cheaper or a 10litre bock of frozen water in the freezer would give you 3 to 5 days. I must be the only Refrigeration engineer who doesn’t have a fridge on his boat pulled ours out as could see to many problems with it as it was old.Fixing what you have would be lucky under $4000.00 even at mates rates Condensor was isolated from the rest of the system luckily and i have a spare condensor to pressure test so hopefully not all bad Quote Link to post Share on other sites
