Anchor chain Young88
2 replies to this topic
#1 Y88 5241
Y88 5241
  • 76 posts
Posted 12 October 2019 - 04:24 PM
What size chain do you recommend for a Young 88 primary anchor?
#2 Y88 Association
Y88 Association
  • 95 posts
Posted 14 October 2019 - 04:59 AM
Hi,
Class rules say:
14.1 (e) One anchor and chain including connection, with a combined anchor and chain weight of 20 kg as a minimum. The chain length shall be at least 9 meters & link diameter at least 8mm. Anchors, chain and rode shall comply with current YNZ safety regulations.
YNZ Safety Regs pg 71 says:
ANCHORS
17.29 Anchors and ground tackle to be carried shall include: Two anchors with:
(i) A cable the boat’s length on deck of chain (min) plus 60m (195ft) of rope or chain, the bitter end of this cable to be secured to the hull.
(ii) A second anchor cable of 6m (19ft 6in) minimum of chain plus 40m (130ft) of rope or chain.
Mandatory Cats 1-3 recommended Cat 4
Floating anchor warp not acceptable. At least one anchor must be complete with tackle and ready for immediate use at all times.
Mandatory Cats all categories
One anchor, a cable the boat’s length of chain and 40m of warp.
Mandatory Cats 4 & 5
Implies..
Minimum required if racing Cat 4 or 5 only:
One anchor and chain including connection, with a combined anchor and chain weight of 20 kg as a minimum. The chain length shall be at least 9 meters & link diameter at least 8mm. Warp/cable length minimum 40m
If racing Cat 1-3 or cruising then as a minimum comply with class rules and relevant YNZ rules
Anchor type is up to you but most boats carry Plows/CQR or Rocna type anchors for cruising and for racing cat 4/5 some will carry an 1 x aluminium Danforth and chain to achieve the 20kg min weight and minimum warp
Apart from complying with rules it is up to you and depends on how well you want to sleep when parked.
Chains Ropes and Anchors might be in a good spot to comment class and YNZ rules plus anchor type...
#3 eighty8
eighty8
    Member
  • Members
  • PipPip
  • 58 posts
Posted 16 October 2019 - 01:01 PM
try Chains Ropes & Anchors Ltd, for an actual chain diam recommendation - displacement about 2700 kgs bare
