Wind Generators
Black Panther
The one and only truely effective way of dealing with "isolating" a wind generator is to throw the damned noisy feeking vibrating thingy overboard.
The sooner the better.
hmmm....
why do people who had wind gens often hate them?
even though rarer on boats, 2nd hand they seem more common on trademe than 2nd hand solar?
when i bought my boat it had a wind gen and solar panel, both fitted in 2006
they probably cost about $500 each at the time
first surprise was noise the rutland 503 put out, if it was windy when people visited they thought the engine was running
part of the noise was chattering due to a wobbly blade
finally got around to testing it and discovered it had no output and it was the 50watt solar that was keeping the two 75a/hr house batteries happy
eventually got around to taking the whole thing down to check the brushes, regulator diodes and replace the bearings
disassembly required desoldering the regulator, which checked out ok
brushes ok too but the wobble turned out to be worn plastic! bearing seats
due to dry or salty? bearings seizing? both races turned and the plastic bearing seats wore creating wobble, the magnets in the rotor to touch the potting mix in the stator and produce more grit and wobble etc
so basically the whole thing should be thrown out or buy another housing for $250?
with nothing to lose decide to shim the worn housing with beer can and after an hour of fiddling got everything back tight and newly greased bearings turning smoothly, resoldered the regulator back and reassembled
and nothing...
realise now that the exposed windings in the stator should not have visible and all the dust inside was worn potting mix
looks like the wobble allowed the rotor magnets to eat into the top face of the windings and short them out
so $500 and a day's work wasted
meanwhile the solar panel has pushed out enough current to keep the batteries topped up, for low use, and has required no maintenance, produces no noise and little windage
solar were good in 2006 but now they are lighter, more efficient and half the price they were
if more charging current is needed, i'll be fitting more 'reliable, fit and forget' solar
BP, those effing windy driven scream machines have deprived millions of sea persons the natural right to a decent kip in noddy land whilst at anchor for decades.
The United Nations should convene a urgent meeting of the Sleep Security Council to resolve this very important matter.
You do know that your kids and wife are also being subject to the same noise abuse and that your beautifully designed and crafted Spencer Schooner is going to perish from the effects of that little roaring rotating dribble charge producing nightmare.
There are quiet ones you know, but they are not cheap. Look at what the professional mariners use in the most unfriendly areas like Henk in TeAma . One of the regular posters on here fitted a Superwind some time back but haven't heard from them in a while. Also the concrete Windflower has one fitted right on top of their bed so cant be too noisy.
Funnily enough the two best rated wind gens overseas are both made in Germany, and are available here through long established companies not trademe fly by night.
