Sign in to follow this
smithy09
Loadcell/ Tension measurement
Its dead simple to use.
Its very interesting finding out what everything weighs. I was told my boat was 700kg. Well the hull and keel is but by the time you add everything you need to go sailing it soon adds up to 850kg.
That includes 50kg of dry sails so I imagine they could be 80kg wet! 10% of the boats weight!
Share this post
Matt has finished breaking things with the loadcell down in Wellington, so if anyone wants to use it, PM me your address and I'll get him to courier it directly to you. Hopefully some photos of Matt's Test rig to come.
Share this post
Yours is just like mine Smithy... only smaller. You can hook that head into a Data Logger or we can and your head does look just like mine. We are close as finishing a new smaller test bead for upto 15,000kg. Finding it tricky playing with the smaller items with 200,000kg ram on the big bed. Most stuff under 10mm has blown to bits before you can even blink. Now we'll get to see it all happen in slower motion.
What was Matt trying to suss?
Share this post
I think I may have done business with you before KM. We destruction tested some crane scales we made on a test rig. Is this your machine??
Matt was destruction testing some carbon fibre stays of some sort...
Share this post
Nope, knot quite that flash :) Mind you that ram is a lot smaller.
Don't know what they were testing there but it looks like a few mis-matched components. Can't have been going for a big load though, a small 2T hook in the mix there by the looks.
I busted some SK90 Dyneema yesterday, that was fun. Took 1645kg to bust a bit of 3mm string, knot too shabby. We didn't really see the failure happen hence the need for a smaller test rig. We like to watch and see how the failure happens even if it does happen at the right load in the right place. You can learn a lot by just how things comes apart.
Chinese chain is fun. We run a sweepstake on how many welds that are under the galv aren't actually welded and just how many links open at the weld before it totally fails.
We do enjoy busting shite :lol:
Share this post
Hahaha. Yeah I enjoy busting stuff as well. If you are not "seeing" the max strain on your loadcell, then you need a "peak hold" function which stores the max force seen. My rig has peak hold..
OK, this place was called "Chain and Rigging" or similar. The Hook was 5t SWL. Our Crane scale was 5000kg capacity, designed and made by me. The loadcell stretched at 10,000kg and the Rod end bearing snapped at just over that... I wasn't prepared to design, build and sell a crane scale without destruction testing the components... You will see a few of my crane scales at Southern Spars if you are ever in there buying a full Carbon rig for the Ross... :D :D
Share this post
